Backward-forward stochastic differential equations, Ann. Appl. Probab, vol.3, pp.777-793, 1993. ,
Sur la topologie des écoulements stationnaires des fluides parfaits, C. R. Acad. Sc, vol.261, pp.17-20, 1965. ,
Translated by Dr. Giuseppe Filipponi from original paper appeared in 1889 in Rendiconti del Reale Instítuto Lombardo, Int. J. Fusion Energy, vol.3, pp.53-57, 1985. ,
Branching process associated with 2 -Navier Stokes equation, Rev. Mat. Iberoam, vol.17, pp.331-373, 2001. ,
Majorizing kernels and stochastic cascades with applications to incompressible Navier-Stokes equations, Trans. Amer. Math. Soc, vol.355, pp.5003-5040, 2003. ,
Strong approximations of BSDEs in a domain, Bernoulli, vol.15, pp.1117-1147, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00446316
Small-scale structure of the Taylor-Green vortex, J. Fluid Mech, vol.130, pp.411-452, 1983. ,
A mathematical model illustrating the theory of turbulence, Adv. Appl. Mech, vol.1, pp.171-199, 1948. ,
Mathematical Geophysics -An introduction to rotating fluids and the Navier-Stokes equations, 2006. ,
URL : https://hal.archives-ouvertes.fr/hal-00112069
Second-order backward stochastic differential equations and fully nonlinear parabolic PDEs, Comm. Pure Appl. Math, vol.60, pp.1081-1110, 2007. ,
New solutions of the kynematic dynamo problem, J. Math. Phys, vol.11, pp.3063-3076, 1970. ,
A numerical method for solving incompressible viscous flow problems, J. Comput. Phys, vol.2, pp.12-26, 1967. ,
Numerical solution of the Navier-Stokes equations, Math. Comp, vol.22, pp.745-762, 1968. ,
On the convergence of discrete approximations to the Navier-Stokes equations, Math. Comp, vol.23, pp.341-353, 1969. ,
Numerical study of slightly viscous flow, J. Fluid Mech, vol.57, pp.785-796, 1973. ,
Vorticity and turbulence, 1998. ,
A stochastic Lagrangian representation of the three-dimensional incompressible Navier-Stokes equations, Comm. Pure Appl. Math, vol.61, pp.330-345, 2008. ,
A stochastic-Lagrangian approach to the Navier-Stokes equations in domains with boundary, Ann. Appl. Probab, vol.21, pp.1466-1492, 2011. ,
Functional quantization-based stratified sampling methods, Monte Carlo Methods Appl, vol.21, pp.1-32, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-00464088
The optimal quantization website, 2005. ,
User's guide to viscosity solutions of second order partial differential equations, Bull. Amer. Math. Soc, vol.27, pp.1-67, 1992. ,
Navier-Stokes equations and forward-backward SDEs on the group of diffeomorphisms of a torus, Stoch. Proc. Appl, vol.119, pp.4034-4060, 2009. ,
On the existence and uniqueness of solutions to FBSDEs in a non-degenerate case, Stoch. Proc. Appl, vol.99, pp.209-286, 2002. ,
A forward-backward stochastic algorithm for quasi-linear PDEs, Ann. Appl. Probab, vol.16, pp.140-184, 2006. ,
URL : https://hal.archives-ouvertes.fr/hal-00002980
An interpolated stochastic algorithm for quasi-linear PDEs, Math. Comp, vol.77, pp.125-158, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00021967
Forward-backward stochastic differential systems associated to Navier-Stokes equations in the whole space, Stoch. Proc. Appl, vol.125, pp.2516-2561, 2015. ,
Principes généraux du mouvement des fluides, Mém. Acad. Roy. Sci. Berlin, vol.11, pp.274-315, 1757. ,
Existence and smoothness of the Navier-Stokes equation, 2000. ,
Space-time approach to non-relativistic quantum mechanics, Rev. Mod. Phys, vol.20, pp.367-387, 1948. ,
A first course in Monte Carlo, 2005. ,
Navier-Stokes equations and turbulence, of Encyclopedia of Mathematics and its Applications, vol.83, 2001. ,
Stochastic vortex method for forced three-dimensional Navier-Stokes equations and pathwise convergence rate, Ann. Appl. Probab, vol.20, pp.1761-1800, 2010. ,
A random space-time birth particle method for 2 vortex equations with external fields, Math. Comp, vol.77, issue.263, pp.1525-1558, 2008. ,
Foundations of quantization for probability distributions, Lecture Notes in Mathematics, vol.1730, 2000. ,
Stochastic integral, Proc. Imp. Acad. Tokyo, vol.20, pp.519-524, 1944. ,
On a stochastic integral equation, Proc. Japan Acad, vol.22, pp.32-35, 1946. ,
A stochastic-Lagrangian particle system for the Navier-stokes equations, Nonlinearity, vol.21, pp.2537-2553, 2008. ,
On distributions of certain Wiener functionals, Trans. Amer. Math. Soc, vol.65, issue.1, pp.1-13, 1949. ,
Efficient Monte Carlo simulation for integral functionals of Brownian motion, J. Complexity, vol.30, pp.255-278, 2014. ,
Stochastic cascades and 3-dimensional Navier-Stokes equations, vol.109, pp.343-366, 1997. ,
A variance reduction technique using a quantized Brownian motion as a control variate, J. Comput. Finance, vol.16, pp.61-84, 2012. ,
URL : https://hal.archives-ouvertes.fr/inria-00393749
Forward-backward stochastic differential equations and their applications, Lecture Notes in Mathematics, vol.1702, 1999. ,
Solving forward-backward stochastic differential equations explicitly -a four step scheme, Probab. Theory Relat. Fields, vol.98, issue.3, pp.339-359, 1994. ,
, Vorticity and incompressible flow, 2002.
Backward stochastic differential equations and quasilinear partial differential equations, Stochastic Partial Differential Equations, vol.216, pp.189-208, 1995. ,
Numerical solution of stochastic differential equations with multiplicative noise, 2017. ,
Stochastic particle approximations for two-dimensional Navier-Stokes equations, Dynamics and Randomness II, vol.10, pp.147-197, 2004. ,
Rate of convergence of the Euler approximation for diffusion processes, Math. Nachr, vol.151, pp.233-239, 1991. ,
Discretization of forward-backward stochastic differential equations and related quasi-linear parabolic equations, IMA J. Numer. Anal, vol.27, issue.1, pp.24-44, 2007. ,
Solving the Dirichlet problem for Navier-Stokes equations by probabilistic approach, BIT Numer. Math, vol.52, pp.141-153, 2012. ,
Probabilistic methods for the incompressible Navier-Stokes equations with space periodic conditions, Adv. Appl. Prob, vol.45, pp.742-772, 2013. ,
Mémoire sur les lois du mouvement des fluides, Mem. Acad. Sci. Inst. France, vol.6, pp.389-440, 1822. ,
A probabilistic representation of solutions of the incompressible Navier-Stokes equations in R 3, Probab. Theory Relat. Fields, vol.133, pp.267-298, 2005. ,
Optimal quadratic quantization for numerics: the Gaussian case, Monte Carlo Methods Appl, vol.9, pp.135-165, 2003. ,
Functional quantization for numerics with an application to option pricing, Monte Carlo Methods Appl, vol.11, pp.407-446, 2005. ,
Backward stochastic differential equations and viscosity solutions of systems of semilinear parabolic and elliptic PDEs of second order, Stochastic Analysis and Related Topics VI, pp.79-127, 1998. ,
Backward stochastic differential equations and quasilinear parabolic partial differential equations, Stochastic Partial Differential Equations and Their Applications, vol.176, pp.200-217, 1992. ,
Adapted solution of a backward stochastic differential equation, Syst. Control Lett, vol.14, pp.55-61, 1990. ,
Forward-backward stochastic differential equations and quasilinear parabolic PDEs, vol.114, pp.123-150, 1999. ,
Calculating effective diffusivities in the limit of vanishing molecular diffusion, J. Comput. Phys, vol.228, pp.1030-1055, 2009. ,
The use of an exact solution of the Navier-Stokes equations in a validation test of a three-dimensional nonhydrostatic numerical model, Mon. Weather Rev, vol.121, pp.2420-2425, 1993. ,
On the theories of the internal friction of fluids in motion, and of the equilibrium and motion of elastic solids, Trans. Camb. Phil. Soc, vol.8, pp.287-319, 1849. ,
A stochastic particle method with random weights for the computation of statistical solutions of McKean-Vlasov equations, Ann. Appl. Probab, vol.13, issue.1, pp.140-180, 2003. ,
URL : https://hal.archives-ouvertes.fr/inria-00072261
An introduction to Navier-Stokes equation and Oceanography, 2006. ,
A staggered space-time discontinuous Galerkin method for the three-dimensional incompressible Navier-Stokes equations on unstructured tetrahedral meshes, J. Comput. Phys, vol.319, pp.294-323, 2016. ,
Mechanism of the production of small eddies from large ones, Proc. R. Soc. Lond. A, vol.158, pp.499-521, 1937. ,
Probability & incompressible Navier-Stokes equations: An overview of some recent developments, Probab. Surv, vol.2, pp.1-32, 2005. ,
A stochastic representation for backward incompressible Navier-Stokes equations, vol.148, pp.305-332, 2010. ,
