Strong differential observability for sampled systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Control and Optimization Année : 2020
In this paper we prove that, generically, a sampled data system is strongly differentially observable provided that the number of outputs is greater than the number of inputs plus one.
strong-dif-M130286.pdf (419.24 Ko) Télécharger le fichier
hal-02377400 , version 1 (23-11-2019)
hal-02377400 , version 2 (01-02-2021)
Sabeur Ammar, Jean-Claude Vivalda, Basma Zitouni. Strong differential observability for sampled systems. SIAM Journal on Control and Optimization, 2020, 58 (6), pp.3814-3841. ⟨10.1137/19M1302867⟩. ⟨hal-02377400v2⟩
80 Consultations
185 Téléchargements
