Optimal solutions for routing problems with profits, Discrete Applied Mathematics, vol.161, issue.4-5, pp.547-557, 2013. ,
, , 2011.
, An exact algorithm for the pickup and delivery problem with time windows, Operations Research, vol.59, issue.2, pp.414-426
, , 2008.
, An exact algorithm for the vehicle routing problem based on the set partitioning formulation with additional cuts, Mathematical Programming, vol.115, pp.351-385
, , 2009.
, A unified exact method for solving different classes of vehicle routing problems, Mathematical Programming, vol.120, issue.2, pp.347-380
, , 2011.
, New route relaxation and pricing strategies for the vehicle routing problem, Operations Research, vol.59, issue.5, pp.1269-1283
On an integer program for a delivery problem, Operations Research, vol.12, issue.2, pp.300-304, 1964. ,
, , 2018.
, A branch-and-cut algorithm for the team orienteering problem, International Transactions in Operational Research, vol.25, issue.2, pp.627-635
, J. a. P, 2016.
, Bin packing and related problems: General arc-flow formulation with graph compression
, Computers & Operations Research, vol.69, pp.56-67
The vehicle routing problem with service level constraints, European Journal of Operational Research, vol.265, issue.2, pp.544-558, 2018. ,
, , 1981.
, Exact algorithms for the vehicle routing problem, based on spanning tree and shortest path relaxations, Mathematical Programming, vol.20, issue.1, pp.255-282
, , 2014.
, A new exact algorithm for the multi-depot vehicle routing problem under capacity and route length constraints, Discrete Optimization, vol.12, pp.129-146
Exact branch-price-and-cut algorithms for vehicle routing, Transportation Science, Forthcoming. References IV Dantzig, vol.6, issue.1, pp.80-91, 1959. ,
, , 2018.
, Enhanced pseudo-polynomial formulations for bin packing and cutting stock problems, INFORMS Journal on Computing
, , 1998.
, A Unified Framework for Deterministic Time Constrained Vehicle Routing and Crew Scheduling Problems, pp.57-93
, , 1992.
, A new optimization algorithm for the vehicle routing problem with time windows, Operations Research, vol.40, issue.2, pp.342-354
, , 2004.
, An exact algorithm for the elementary shortest path problem with resource constraints: Application to some vehicle routing problems, Networks, vol.44, issue.3, pp.216-229
, , 2006.
, Robust branch-and-cut-and-price for the capacitated vehicle routing problem, Mathematical Programming, vol.106, issue.3, pp.491-511
Bidirectional labeling in column-generation algorithms for pickup-and-delivery problems, 2018. ,
, European Journal of Operational Research, vol.266, issue.2, pp.521-530
, , 2017.
, Gurobi optimizer reference manual, version 7.5. References VI Heßler, 2018.
, Stabilized branch-and-price algorithms for vector packing problems, European Journal of Operational Research, vol.271, issue.2, pp.401-419
, , 2010.
, Path-reduced costs for eliminating arcs in routing and scheduling, INFORMS Journal on Computing, vol.22, issue.2, pp.297-313
The shortest-path problem with resource constraints and k-cycle elimination for k ? 3, INFORMS Journal on Computing, vol.18, issue.3, pp.391-406, 2006. ,
, , 2008.
, Subset-row inequalities applied to the vehicle-routing problem with time windows, Operations Research, vol.56, issue.2, pp.497-511
, References VII
, , 1983.
, A branch and bound algorithm for the capacitated vehicle routing problem, Operations-Research-Spektrum, vol.5, issue.2, pp.77-85
, , 2016.
, An exact algorithm for the elementary shortest path problem with resource constraints, Transportation Science, vol.50, issue.1, pp.348-357
, , 2004.
, A new branch-and-cut algorithm for the capacitated vehicle routing problem, Mathematical Programming, vol.100, issue.2, pp.423-445
New enhancements for the exact solution of the vehicle routing problem with time windows, INFORMS Journal on Computing, vol.29, issue.3, pp.489-502, 2017. ,
Improved branch-cut-and-price for capacitated vehicle routing, Mathematical Programming Computation, vol.9, issue.1, pp.61-100, 2017. ,
Limited memory rank-1 cuts for vehicle routing problems, Operations Research Letters, vol.45, issue.3, pp.206-209, 2017. ,
, , 2019.
, Comparative analysis of capacitated arc routing formulations for designing a new branch-cut-and-price algorithm, Transportation Science
Robust branch-cut-and-price algorithms for vehicle routing problems, The Vehicle Routing Problem: Latest Advances and New Challenges, vol.43, pp.297-325, 2008. ,
Enhanced branch-cut-and-price algorithm for heterogeneous fleet vehicle routing problems, European Journal of Operational Research, vol.270, pp.530-543, 2018. ,
A generic exact solver for vehicle routing and related problems, Integer Programming and Combinatorial Optimization, vol.11480, pp.354-369, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02178171
, , 2014.
, New Exact Algorithms for the Capacitated Vehicle Routing Problem, pp.59-86
, , 2012.
, An exact method with variable fixing for solving the generalized assignment problem, Computational Optimization and Applications, vol.52, pp.629-644
Symmetry helps: Bounded bi-directional dynamic programming for the elementary shortest path problem with resource constraints, Discrete Optimization, vol.3, issue.3, pp.255-273, 2006. ,
, , 2014.
, Dynamic ng-path relaxation for the delivery man problem, Transportation Science, vol.48, issue.3, pp.413-424
, , 2012.
, Branching decisions in branch-and-cut-and-price algorithms for vehicle routing problems. Presentation in Column Generation, 2012.
, , 2017.
, A bucket graph based labeling algorithm with application to vehicle routing. Cadernos do LOGIS 7
Asymmetry matters: Dynamic half-way points in bidirectional labeling for solving shortest path problems with resource constraints faster, European Journal of Operational Research, vol.261, issue.2, pp.530-539, 2017. ,
, , 2017.
, New benchmark instances for the capacitated vehicle routing problem, European Journal of Operational Research, vol.257, issue.3, pp.845-858
, , 2019.
, A new branch-and-price-and-cut algorithm for one-dimensional bin-packing problems, INFORMS Journal on Computing
