An immersed boundary method using unstructured anisotropic mesh adaptation combined with level-sets and penalization techniques, Journal of Computational Physics, vol.257, pp.83-101, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00786853
Adaptation de maillage anisotrope en trois dimensions. Application aux simulations instationnaires en Mécanique des Fluides, 2003. ,
A parallel matrix-free conservative solution interpolation on unstructured tetrahedral meshes, Computer Methods in Applied Mechanics and Engineering, vol.299, pp.116-142, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01211749
Wolf documentation. a navier-stokes flow solver based on the mixed elementvolume numerical scheme, Internal report, 2019. ,
P1-conservative solution interpolation on unstructured triangular meshes, International Journal for Numerical Methods in Engineering, vol.84, issue.13, 2010. ,
URL : https://hal.archives-ouvertes.fr/inria-00354509
Magnetic cage and rope as the key for solar eruptions, Nature, vol.554, pp.211-215, 2018. ,
URL : https://hal.archives-ouvertes.fr/cea-01872913
A penalization method to take into account obstacles in incompressible flows, Numerische Mathematik, vol.81, pp.497-520, 1999. ,
The p-version of the finite element method, SIAM journal on numerical analysis, vol.18, issue.3, pp.515-545, 1981. ,
A posteriori error estimates based on hierarchical bases, SIAM Journal on Numerical Analysis, vol.30, issue.4, pp.921-935, 1993. ,
Time-accurate anisotropic mesh adaptation for three-dimensional moving mesh problems, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01426156
On the Choice of Wavespeeds for the HLLC Riemann Solver, SIAM Journal on Scientific Computing, vol.18, issue.6, pp.1553-1570, 1997. ,
A 3D chimera grid embedding technique, 7th AIAA Computational Fluid Dynamics Conference, 1523. ,
Adaptive mesh refinement for hyperbolic partial differential equations, Journal of computational Physics, vol.53, issue.3, pp.484-512, 1984. ,
Boundary-volume mesh generation and adaptation for turbulent flows around complex geometries, 2016. ,
URL : https://hal.archives-ouvertes.fr/tel-01712438
Improved 3d adaptive remeshing scheme applied in high electromagnetic field gradient computation. Finite Elements in Analysis and Design, vol.46, pp.84-95, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-01810049
Adaptive remeshing in large plastic strain with damage, International Journal for Numerical Methods in Engineering, vol.63, issue.1, pp.1-36, 2005. ,
URL : https://hal.archives-ouvertes.fr/hal-02276019
Metric-based anisotropic mesh adaptation for 3D acoustic boundary element methods, Journal of Computational Physics, vol.372, pp.473-499, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01895636
Approximation by finite element functions using local regularization, ESAIM: Mathematical Modelling and Numerical Analysis -Modélisation Mathématique et Analyse Numérique, vol.9, issue.R2, pp.77-84, 1975. ,
Very high order anisotropic metric-based mesh adaptation in 3d, Procedia Engineering, vol.163, pp.353-364, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01438226
Mixed-element-volume muscl methods with weak viscosity for steady and unsteady flow calculations, Computers & Fluids, vol.29, issue.1, pp.89-118, 2000. ,
3D anisotropic mesh adaptation and application for air-conditionning, 2005. ,
URL : https://hal.archives-ouvertes.fr/tel-00120327
An adaptive simplex cut-cell method for discontinuous Galerkin discretizations of the Navier-Stokes equations, 18th AIAA Computational Fluid Dynamics Conference, 2007. ,
Triangular cut-cell adaptive method for high-order discretizations of the compressible Navier-Stokes equations, Journal of Computational Physics, vol.225, pp.1653-1672, 2007. ,
3D anisotropic mesh adaptation for Reynolds Averaged Navier-Stokes simulations, UPMC, 2018. ,
URL : https://hal.archives-ouvertes.fr/tel-01962318
Anisotropic mesh adaptation for cfd computations, Computer methods in applied mechanics and engineering, vol.194, pp.5068-5082, 2005. ,
Goal-oriented metric-based mesh adaptation for unsteady CFD simulations involving moving geometries, 2018. ,
URL : https://hal.archives-ouvertes.fr/tel-02272727
Meshing, Geometric Modeling and Numerical Simulation 2: Metrics, Meshes and Mesh Adaptation, 2019. ,
Immersed stress method for fluidstructure interaction using anisotropic mesh adaptation, International Journal for Numerical Methods in Engineering, vol.94, issue.9, pp.805-825, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00815641
Ii.5. -the pleasures of "perp dot" products, Graphics Gems, pp.138-148, 1994. ,
URL : https://hal.archives-ouvertes.fr/in2p3-00159268
A new anisotropic mesh adaptation method based upon hierarchical a posteriori error estimates, Journal of Computational Physics, vol.229, pp.2179-2198, 2010. ,
A robust upwind discretization method for advection, diffusion and source terms, Numerical methods for advection-diffusion problems, pp.117-138, 1993. ,
Applied computational fluid dynamics techniques: an introduction based on finite element methods, 2008. ,
Comparison of body-fitted, embedded and immersed solutions of low Reynolds-number 3-d incompressible flows, 45th AIAA Aerospace Sciences Meeting, 1296. ,
Adaptive h-refinement on 3d unstructured grids for transient problems, International Journal for Numerical Methods in Fluids, vol.14, issue.12, pp.1407-1419, 1992. ,
Adaptive embedded unstructured grid methods, International Journal for Numerical Methods Engineering, vol.60, pp.641-660, 2004. ,
Comparison of body-fitted, embedded and immersed 3-d Euler predictions for blast loads on columns, 45th AIAA Aerospace Sciences Meeting, 1113. ,
Adaptation de maillage anisotrope 3D multi-échelles et ciblée à une fonctionnelle pour la mécanique des fluides : Application à la prédiction haute-fidélité du bang sonique, 2008. ,
Continuous mesh framework part I: well-posed continuous interpolation error, SIAM J. Numer. Anal, vol.49, issue.1, pp.38-60, 2011. ,
Continuous mesh framework part II: validations and applications, SIAM J. Numer. Anal, vol.49, issue.1, pp.61-86, 2011. ,
Robust boundary layer mesh generation, Proceedings of the 21st International Meshing Roundtable, pp.493-511, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00935315
Numerical methods and mesh adaptation for reliable RANS simulations, 2015. ,
URL : https://hal.archives-ouvertes.fr/tel-01243012
Anisotropic metric-based mesh adaptation for unsteady CFD simulations involving moving geometries, 2011. ,
URL : https://hal.archives-ouvertes.fr/tel-00739406
Validation of an output-adaptive tetrahedral cut-cell method for sonic boom prediction, AIAA Journal, vol.48, issue.9, pp.1928-1945, 2010. ,
Flow patterns around heart valves: A numerical method, Journal of Computational Physics, vol.10, issue.2, pp.252-271, 1972. ,
Criteria for the design of limiters yielding efficient high resolution tvd schemes, Computers & Fluids, vol.27, issue.2, pp.183-197, 1998. ,
URL : https://hal.archives-ouvertes.fr/hal-00607768
A conservative Embedded Boundary method for an inviscid compressible flow coupled with a fragmenting structure, International Journal for Numerical Methods in Engineering, vol.103, issue.13, pp.970-995, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01071619
Anisotropic adaptive nearly body-fitted meshes for cfd, Engineering with Computers, vol.30, issue.4, pp.517-533, 2014. ,
Anisotropic mesh adaptation with optimal convergence for finite elements using embedded geometries, Computer Methods in Applied Mechanics and Engineering, vol.268, pp.65-81, 2014. ,
Génération de maillages éléments finis anisotropes et adaptatifs, 1992. ,
Towards the ultimate conservative difference scheme. A second-order sequel to Godunov's method, Journal of Computational Physics, pp.101-136, 1979. ,
A direct-forcing embedded-boundary method with adaptive mesh refinement for fluid-structure interaction problems, Journal of Computational Physics, vol.229, issue.18, pp.6427-6449, 2010. ,
Mesh adaptation for fluid-structure interaction problems, 24th AIAA Fluid Dynamics Conference, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01962204
Algorithms for interface treatment and load computation in embedded boundary methods for fluid and fluid-structure interaction problems, International Journal for Numerical Methods in Fluids, vol.67, pp.1175-1206, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00651118
A Cartesian cut cell method for compressible flows part A: Static body problems, Aeronautical Journal, vol.101, pp.47-56, 1002. ,
A cartesian cut cell method for compressible flows Part B: moving body problems, Aeronautical Journal, vol.101, pp.57-65, 1002. ,
The superconvergent patch recovery and a posteriori error estimates. part 1: The recovery technique, International Journal for Numerical Methods in Engineering, vol.33, issue.7, pp.1331-1364, 1992. ,
The superconvergent patch recovery and a posteriori error estimates. part 2: Error estimates and adaptivity, International Journal for Numerical Methods in Engineering, vol.33, issue.7, pp.1365-1382, 1992. ,
