, , 2008.
, An exact algorithm for the vehicle routing problem based on the set partitioning formulation with additional cuts, Mathematical Programming, vol.115, pp.351-385
, , 2011.
, New route relaxation and pricing strategies for the vehicle routing problem, Operations Research, vol.59, issue.5, pp.1269-1283
The vehicle routing problem with backhauls, European Journal of Operational Research, vol.42, issue.1, pp.39-51, 1989. ,
, , 2019.
, A mixed integer linear programming formulation for the vehicle routing problem with backhauls, International Journal of Industrial Engineering Computations, vol.10, issue.2, pp.295-308
, , 2018.
, Vehicle routing with backhauls: Review and research perspectives, Computers and Operations Research, vol.91, pp.79-91
, , 1983.
, A branch and bound algorithm for the capacitated vehicle routing problem, Operations-Research-Spektrum, vol.5, issue.2, pp.77-85
, , 2003.
, CVRPSEP: a package of separation routines for the capacitated vehicle routing problem
, , 1999.
, An exact method for the vehicle routing problem with backhauls, Transportation Science, vol.33, issue.3, pp.315-329
Improved branch-cut-and-price for capacitated vehicle routing, Mathematical Programming Computation, vol.9, issue.1, pp.61-100, 2017. ,
A generic exact solver for vehicle routing and related problems, Integer Programming and Combinatorial Optimization, vol.11480, pp.354-369, 2019. ,
, , 1997.
, An exact algorithm for the vehicle routing problem with backhauls, Transportation Science, vol.31, issue.4, pp.372-385
, , 2017.
, New benchmark instances for the capacitated vehicle routing problem, European Journal of Operational Research, vol.257, issue.3, pp.845-858
