Automatic analysis of facial affect: A survey of registration, representation, and recognition, IEEE Trans. on Pattern Analysis and Machine Intelligence, vol.37, issue.6, pp.1113-1133, 2015. ,
Emotions revealed: Recognizing faces and feelings to improve communication and emotional life, New York: Times Books, 2003. ,
Recognizing subtle micro-facial expressions using fuzzy histogram of optical flow orientations and feature selection methods, Comput. Intell. for Pattern Recog, pp.341-368, 2018. ,
An efficient unconstrained facial expression recognition algorithm based on stack binarized auto-encoders and binarized neural networks, Neurocomputing, vol.267, pp.385-395, 2017. ,
Adaptive feature mapping for customizing deep learning based facial expression recognition model, IEEE Access, vol.6, pp.12-451, 2018. ,
Conditional convolution neural network enhanced random forest for facial expression recognition, Pattern Recognition (PR), vol.84, pp.251-261, 2018. ,
Characterizing the state of apathy with facial expression and motion analysis, IEEE Int. Conf. on Automatic Face & Gesture Recognition (FG 2019), 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02379341
Action unit selective feature maps in deep networks for facial expression recognition, Int. Joint Conf. on Neural Networks (IJCNN), pp.2031-2038, 2017. ,
Manifold based analysis of facial expression, Image and Vision Computing, vol.24, issue.6, pp.605-614, 2006. ,
A discriminant manifold non-negative matrix factorization algorithm for facial expression recognition, IEEE Int. Conf. on Signal Processing, pp.1010-1015, 2016. ,
Discriminant multi-label manifold embedding for facial action unit detection, Int. Conf. and Workshops on Automatic Face and Gesture Recognition (FG), vol.6, pp.1-6, 2015. ,
Learning expressionlets via universal manifold model for dynamic facial expression recognition, IEEE Trans. on Image Processing, vol.25, issue.12, pp.5920-5932, 2016. ,
Projection into expression subspaces for face recognition from single sample per person, IEEE Trans. on Affective Computing, vol.4, issue.1, pp.69-82, 2013. ,
Grassmann discriminant analysis: a unifying view on subspace-based learning, Int. Conf. on Machine learning, pp.376-383, 2008. ,
Learning prototypes and similes on grassmann manifold for spontaneous expression recognition, Computer Vision and Image Understanding, vol.147, pp.95-101, 2016. ,
Histograms of oriented gradients for human detection, IEEE Conf. on Computer Vision and Pattern Recognition, vol.1, pp.886-893, 2005. ,
URL : https://hal.archives-ouvertes.fr/inria-00548512
Local binary patterns for multi-view facial expression recognition, Computer Vision and Image Understanding, vol.115, issue.4, pp.541-558, 2011. ,
On the design and applicability of distance functions in high-dimensional data space, IEEE Trans. on Knowledge and Data Engineering, vol.21, issue.4, pp.523-536, 2009. ,
Locally linear models on face appearance manifolds with application to dual-subspace based classification, Computer Vision and Pattern Recognition, vol.2, pp.1384-1390, 2006. ,
Learning over sets using boosted manifold principal angles (bompa), British Machine Vision Conf, pp.58-59, 2005. ,
Manifold-manifold distance with application to face recognition based on image set, IEEE Conf. on Computer Vision and Pattern Recognition, pp.1-8, 2008. ,
A global geometric framework for nonlinear dimensionality reduction, Science, vol.290, issue.5500, pp.2319-2323, 2000. ,
Dynamic model of facial expression recognition based on eigen-face approach, IEEE Proc. of Green Energy and Systems Conf. IEEE, 2013. ,
The extended cohn-kanade dataset (ck+): A complete dataset for action unit and emotion-specified expression, IEEE Computer Vision and Pattern Recognition -Workshops on human communicative behavior analysis, pp.94-101, 2010. ,
Coding facial expressions with gabor wavelets, IEEE Int. Conf. and Workshops on Automatic Face and Gesture Recognition (FG), pp.200-205, 1998. ,
Presentation and validation of the radboud faces database, Cognition and Emotion, vol.24, issue.8, pp.1377-1388, 2010. ,
Facesa database of facial expressions in young, middle-aged, and older women and men: Development and validation, Behavior research methods, vol.42, issue.1, pp.351-362, 2010. ,
Robust facial expression recognition algorithm based on local metric learning, Journal of Electronic Imaging, vol.25, issue.1, 2016. ,
Facial expression recognition and histograms of oriented gradients: a comprehensive study, SpringerPlus, vol.4, issue.1, p.645, 2015. ,
Facial expression recognition influenced by human aging, IEEE Trans. on Affective Computing, vol.4, issue.3, pp.291-298, 2013. ,
Expressioninvariant age estimation using structured learning, IEEE Trans. on Pattern Analysis and Machine Intelligence (PAMI), vol.40, issue.2, pp.365-375, 2018. ,
Enhanced facial expression recognition by age, IEEE Int. Conf. and Workshops on Automatic Face and Gesture Recognition (FG), vol.1, pp.1-6, 2015. ,
