An exact algorithm for the vehicle routing problem based on the set partitioning formulation with additional cuts, Mathematical Programming, vol.115, pp.351-385, 2008. ,
New route relaxation and pricing strategies for the vehicle routing problem, Operations Research, vol.59, pp.1269-1283, 2011. ,
A new tabu search algorithm for the vehicle routing problem with backhauls, European Journal of Operational Research, vol.173, pp.540-555, 2006. ,
A deterministic iterated local search algorithm for the vehicle routing problem with backhauls, TOP, vol.24, pp.445-465, 2016. ,
A new exact algorithm for the multi-depot vehicle routing problem under capacity and route length constraints, Discrete Optimization, vol.12, pp.129-146, 2014. ,
An iterated local search algorithm for the vehicle routing problem with backhauls, European Journal of Operational Research, vol.237, pp.454-464, 2014. ,
Extension of the clarke and wright algorithm for solving the vehicle routing problem with backhauling, Proceedings of the Babson conference on software uses in transportation and logistics management, pp.75-96, 1984. ,
Jump: A modeling language for mathematical optimization, SIAM Review, vol.59, pp.295-320, 2017. ,
A generalized assignment heuristic for vehicle routing, Networks, vol.11, pp.109-124, 1981. ,
Multi-ant colony system (macs) for a vehicle routing problem with backhauls, European Journal of Operational Research, vol.196, pp.102-117, 2009. ,
A new branching strategy for time constrained routing problems with application to backhauling, Annals of Operations Research, vol.61, pp.91-109, 1995. ,
The vehicle routing problem with backhauls, European Journal of Operational Research, vol.42, pp.39-51, 1989. ,
A mixed integer linear programming formulation for the vehicle routing problem with backhauls, International Journal of Industrial Engineering Computations, vol.10, pp.295-308, 2019. ,
The Vehicle Routing Problem with Backhauls: Properties and Solution Algorithms, 1992. ,
Subset-row inequalities applied to the vehicle-routing problem with time windows, Operations Research, vol.56, pp.497-511, 2008. ,
Vehicle routing with backhauls: Review and research perspectives, Computers & Operations Research, vol.91, pp.79-91, 2018. ,
An exact algorithm for the asymmetrical capacitated vehicle routing problem, Networks, vol.16, pp.33-46, 1986. ,
CVRPSEP: A package of separation routines for the Capacitated Vehicle Routing Problem, 2003. ,
An exact method for the vehicle routing problem with backhauls, Transportation Science, vol.33, pp.315-329, 1999. ,
A reactive tabu search meta-heuristic for the vehicle routing problem with back-hauls, Journal of Scheduling, vol.5, pp.263-285, 2002. ,
Improved branch-cut-and-price for capacitated vehicle routing, Mathematical Programming Computation, vol.9, pp.61-100, 2017. ,
Limited memory rank-1 cuts for vehicle routing problems, Operations Research Letters, vol.45, pp.206-209, 2017. ,
A hybrid heuristic for a broad class of vehicle routing problems with heterogeneous fleet, Annals of Operations Research, vol.273, pp.5-74, 2019. ,
Automation and combination of linear-programming based stabilization techniques in column generation, INFORMS Journal on Computing, vol.30, pp.339-360, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01077984
A generic exact solver for vehicle routing and related problems, Integer Programming and Combinatorial Optimization, pp.354-369, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02178171
A Generic Exact Solver for Vehicle Routing and Related Problems. Cadernos do LOGIS, 2019. ,
Chapter 3: New exact algorithms for the capacitated vehicle routing problem, Vehicle routing: problems, methods, and applications chapter, pp.59-86, 2014. ,
A unified heuristic for a large class of vehicle routing problems with backhauls, European Journal of Operational Research, vol.171, pp.750-775, 2006. ,
A bucket graph based labeling algorithm with application to vehicle routing, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01664854
A hybrid algorithm for a class of vehicle routing problems, Computers & Operations Research, vol.40, pp.2519-2531, 2013. ,
A heuristic algorithm for the vehicle routing problem with backhauls, 1996. ,
, Advanced Methods in Transportation Analysis, pp.585-608
An exact algorithm for the vehicle routing problem with backhauls, Transportation Science, vol.31, pp.372-385, 1997. ,
An interactive GRAMPS algorithm for the heterogeneous fixed fleet vehicle routing problem with and without backhauls, European Journal of Operational Research, vol.201, pp.593-600, 2010. ,
New benchmark instances for the capacitated vehicle routing problem, European Journal of Operational Research, vol.257, pp.845-858, 2017. ,
BaPCod -a generic branch-and-price code, 2018. ,
A unified solution framework for multi-attribute vehicle routing problems, European Journal of Operational Research, vol.234, pp.658-673, 2014. ,
Reactive tabu adaptive memory programming search for the vehicle routing problem with backhauls, Journal of the Operational Research Society, vol.58, pp.1630-1641, 2007. ,
Vehicle routing at quality stores, INFORMS Journal on Applied Analytics, vol.17, pp.52-63, 1987. ,
An effective local search approach for the vehicle routing problem with backhauls, Expert Systems with Applications, vol.39, pp.3174-3184, 2012. ,
