Second-order cone programming, Math. Program., Ser. B, vol.95, issue.1, pp.3-51, 2003. ,
A simple proof of the restricted isometry property for random matrices, Constr. Approx, vol.28, issue.3, pp.253-263, 2008. ,
A Lasso for hierarchical interactions, Ann. Statist, vol.41, issue.3, pp.1111-1141, 2013. ,
Generalized separable potentials for electronic-structure calculations, Phys. Rev. B, vol.41, pp.5414-5416, 1990. ,
Iterative hard thresholding for compressed sensing, Appl. Comp. Harm. Anal, vol.27, issue.3, pp.265-274, 2009. ,
Normalized iterative hard thresholding: Guaranteed stability and performance, IEEE J. Selected Topics in Signal Proc, vol.4, issue.2, pp.298-309, 2010. ,
The restricted isometry property and its implications for compressed sensing, Comptes Rendus Mathematique, vol.346, issue.9, pp.589-592, 2008. ,
1 -magic: Recovery of sparse signals via convex programming, 2005. ,
Exact and stable covariance estimation from quadratic sampling via convex programming, IEEE Trans. Inf. Theory, issue.7, pp.4034-4059, 2015. ,
Variable selection with the strong heredity constraint and its oracle property, J. Amer. Statist. Assoc, vol.105, issue.489, pp.354-364, 2010. ,
Convergence rates of best n-term Galerkin approximations for a class of elliptic spdes, Found. Comp. Math, vol.10, issue.6, pp.615-646, 2010. ,
Tight conditions for consistency of variable selection in the context of high dimensionality, Ann. Statist, vol.40, issue.5, pp.2667-2696, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00602211
Tight conditions for consistent variable selection in high dimensional nonparametric regression, J. Mach. Learn. Res, vol.19, pp.187-206, 2012. ,
URL : https://hal.archives-ouvertes.fr/inria-00566721
Statistical inference in compound functional models. Probability Theory and Related Fields, vol.158, pp.513-532, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00725663
Approximation of functions of few variables in high dimensions, Constr. Approx, vol.33, pp.125-143, 2011. ,
Exploiting separability in multiagent planning with continuous-state mdps, Proceedings of the 2014 International Conference on Autonomous Agents and Multi-agent Systems, AAMAS '14, pp.1281-1288, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01092066
A mathematical introduction to compressive sensing ,
, , 2013.
Big data of materials science: Critical role of the descriptor, Phys. Rev. Lett, vol.114, issue.10, p.105503, 2015. ,
System estimation from metabolic time-series data, Bioinformatics, vol.24, issue.21, pp.2505-2511, 2008. ,
On the unconstrained optimization of partially separable functions, pp.301-312, 1981. ,
A bound on tail probabilities for quadratic forms in independent random variables, Ann. Math. Stat, vol.42, issue.3, pp.1079-1083, 1971. ,
Sparse grid quadrature in high dimensions with applications in finance and insurance, vol.77, 2010. ,
Variable selection in nonparametric additive models, Ann. Statist, vol.38, issue.4, pp.2282-2313, 2010. ,
Sparse volterra and polynomial regression models: Recoverability and estimation, Trans. Sig. Proc, vol.59, issue.12, pp.5907-5920, 2011. ,
Sparse recovery in large ensembles of kernel machines, 21st Annual Conference on Learning Theory (COLT), pp.229-238, 2008. ,
Sparsity in multiple kernel learning, Ann. Statist, vol.38, issue.6, pp.3660-3695, 2010. ,
Component selection and smoothing in multivariate nonparametric regression, Ann. Statist, vol.34, issue.5, pp.2272-2297, 2006. ,
High-dimensional additive modeling, Ann. Statist, vol.37, issue.6B, pp.3779-3821, 2009. ,
Learning juntas, 35th Annual ACM Symposium on Theory of Computing (STOC), pp.206-212, 2003. ,
Sparse interactions: Identifying high-dimensional multilinear systems via compressed sensing, 48th Annual Allerton Conference on Communication, Control, and Computing (Allerton), pp.1589-1596, 2010. ,
Interior-Point Polynomial Algorithms in Convex Programming, Society for Industrial and Applied Mathematics, 1994. ,
Function spaces in lipschitz domains and optimal rates of convergence for sampling, Constr. Approx, vol.23, issue.3, pp.325-350, 2006. ,
Approximation of infinitely differentiable multivariate functions is intractable, J. Compl, vol.25, pp.398-404, 2009. ,
Variable selection using adaptive nonlinear interaction structures in high dimensions, J. Amer. Statist. Assoc, vol.105, pp.1541-1553, 2010. ,
Minimax-optimal rates for sparse additive models over kernel classes via convex programming, J. Mach. Learn. Res, vol.13, issue.1, pp.389-427, 2012. ,
Compressive sensing and structured random matrices. Theoretical foundations and numerical methods for sparse recovery, vol.9, pp.1-92, 2010. ,
Sparse additive models, J. Royal Statist. Soc.: Series B (Statistical Methodology), vol.71, issue.5, pp.1009-1030, 2009. ,
Compressed learning of high-dimensional sparse functions, IEEE International Conference on Acoustics, Speech and Signal Processing (ICASSP), pp.3924-3927, 2011. ,
Survey of modeling and optimization strategies to solve highdimensional design problems with computationally-expensive black-box functions, Struct. Multidiscip. Optim, vol.41, issue.2, pp.219-241, 2010. ,
Surface estimation, variable selection, and the nonparametric oracle property, Statistica Sinica, vol.21, issue.2, pp.679-705, 2011. ,
Efficient sampling for learning sparse additive models in high dimensions, Advances in Neural Information Processing Systems (NIPS) 27, pp.514-522, 2014. ,
Learning sparse additive models with interactions in high dimensions, 19th International Conference on Artificial Intelligence and Statistics (AISTATS), pp.111-120, 2016. ,
Algorithms for learning sparse additive models with interactions in high dimensions. Information and Inference: A, Journal of the IMA, p.8, 2017. ,
Introduction to the non-asymptotic analysis of random matrices, Compressed Sensing: Theory and Applications, pp.210-268, 2012. ,
Sampling numbers and function spaces, J. Compl, vol.23, issue.4-6, pp.773-792, 2007. ,
Widths of embeddings in function spaces, J. Compl, vol.24, issue.4, pp.545-570, 2008. ,
Variable selection in high-dimensional additive models based on norms of projections, 2015. ,
Moments and absolute moments of the normal distribution, 2014. ,
Minimax-optimal nonparametric regression in high dimensions, Ann. Statist, vol.43, issue.2, pp.652-674, 2015. ,
Value function approximation for the control of multiscale dynamical systems, 2016 IEEE 55th Conference on Decision and Control (CDC), pp.5471-5477, 2016. ,
