Resonances of an elastic plate in a compressible 825 confined fluid, The Quarterly Journal of Mechanics and Applied Mathematics, vol.60, issue.4, p.827, 2007. ,
Resonances of an elastic plate coupled with a com-828 pressible confined flow, The Quarterly Journal of Mechanics and Applied Mathematics, vol.829, issue.2, p.830, 2009. ,
A Modern Course in Aeroelasticity, p.832, 1989. ,
An Introduction to the Theory of Aeroelasticity, p.833, 1955. ,
Aeroelastic instability of cantilevered 834 flexible plates in uniform flow, J. Fluid Mech, vol.611, p.835, 2008. ,
An Experimental Study of Paper Flut-836 ter, Journal of Fluids and Structures, vol.16, issue.4, p.837, 2002. ,
A Theoretical Study of Paper Flutter, Journal of Fluids and Structures, vol.838, issue.4, p.839, 2002. ,
Instability of a cantilevered flexible plate in viscous channel 840 flow, Journal of Fluids and Structures, vol.20, p.841, 2005. ,
Stability of rectangular plates with free side-edges in two-842 dimensional inviscid channel flow, Journal of Applied Mechanics, vol.67, issue.1, p.843, 2000. ,
Existence theorems for trapped modes, Journal 844 of Fluid Mechanics, vol.261, p.845, 1994. ,
Trapped modes in acoustic waveguides, The Quarterly 846 Journal of Mechanics and Applied Mathematics, vol.51, issue.3, p.847, 1998. ,
Trapped modes in a waveguide with a long 848 obstacle, Journal of Fluid Mechanics, vol.403, p.849, 2000. ,
Stability and acoustic scattering in a cylindrical thin shell 850 containing compressible mean flow, Journal of Fluid Mechanics, vol.602, p.851, 2008. ,
Asymptotic study of the vibration problem for an elastic body deeply 852 immersed in an incompressible fluid, Math. Model. Numer. Anal, vol.19, p.853, 1985. ,
Nonhomogeneous media and vibration theory, vol.854, p.855, 1980. ,
On the vibration problem for an elastic body surrounded 856 by a slightly compressible fluid, RAIRO Anal. Numr, vol.17, p.857, 1983. ,
Vibration and Coupling of Continuous Systems, p.858 ,
, Asymptotics Methods, p.859, 1989.
Asymptotic Analysis Relating Spectral Models in 860 Fluid-Solid Vibrations, SIAM journal on numerical analysis, vol.35, issue.3, p.861, 1998. ,
Existence and uniqueness of a solution to an aeroacoustic 862 model, Chinese Ann. Math. Ser. B, vol.23, p.863, 2002. ,
Modelling and control of noise in a flexible flow duct, Methods in Applied Mechanics and Engineering, vol.197, p.865, 2008. ,
Exact controllability of an aeroacoustic model 866 with a Neumann and a Dirichlet boundary control, SIAM Journal on Control and Opti-867 mization, vol.48, issue.3, p.868, 2009. ,
A noise control problem arising in a flow duct, SIAM Journal 869 on Applied Mathematics, vol.64, issue.6, p.870, 2004. ,
Trapped mode frequencies embedded in the con-871 tinuous spectrum, The Quarterly Journal of Mechanics and Applied Mathematics, vol.46, issue.2, pp.253-274, 1993. ,
Examples of Embedded Eigenvalues for Problems in Acoustic Waveguides, p.874 ,
, Mathematical Methods in the Applied Sciences, vol.21, issue.6, p.875, 1998.
Embedded RayleighBloch surface waves along periodic rectan-876 gular arrays, Wave motion, vol.43, issue.1, p.877, 2005. ,
The importance of the unsteady Kutta condition when 878 modelling gustaerofoil interaction, Journal of Sound and Vibration, vol.378, pp.28-37, 2016. ,
Resonant Acoustic Frequencies of Flat Plate Cascades, Journal of Sound, vol.880, issue.2, p.881, 1983. ,
Cut-on cut-off transition in flow ducts: com-882 paring multiple-scales and finite-element solutions ,
, AIAA/CEAS Aeroacoustics Conference, pp.10-12, 2004.
Complex resonances in acoustic waveguides, p.885 ,
, The Quarterly Journal of Mechanics and Applied Mathematics, vol.53, issue.3, p.886, 2000.
Complex resonances and trapped modes in ducted domains, Journal of Fluid 887 Mechanics, vol.571, p.888, 2007. ,
Variational formulations for the determina-889 tion of resonant states in scattering problems, SIAM journal on mathematical analysis, vol.890, issue.3, p.891, 1992. ,
Determination of scattering frequencies for an elastic floating 892 body, SIAM journal on mathematical analysis, vol.24, issue.6, p.893, 1993. ,
, Library of Finite Elements in C++
