Face sketch synthesis and recognition, IEEE ICCV, pp.687-694, 2003. ,
Face sketch recognition, IEEE Trans. CSVT, vol.14, issue.1, pp.50-57, 2004. ,
A nonlinear approach for face sketch synthesis and recognition, IEEE CVPR, pp.1005-1010, 2005. ,
Bayesian tensor inference for sketchbased facial photo hallucination, IJCAI, pp.2141-2146, 2007. ,
Face photo-sketch synthesis and recognition, IEEE Trans. PAMI, vol.31, issue.11, pp.1955-1967, 2009. ,
Coupled information-theoretic encoding for face photo-sketch recognition, IEEE CVPR, pp.513-520, 2011. ,
Heterogeneous face recognition using kernel prototype similarities, IEEE Trans. PAMI, vol.35, issue.6, pp.1410-1422, 2013. ,
Matching composite sketches to face photos: A component-based approach, IEEE Trans. IFS, vol.8, issue.1, pp.191-204, 2013. ,
Transfer learning based evolutionary algorithm for composite face sketch recognition, IEEE CVPR Workshops, pp.619-627, 2017. ,
Face sketch matching via coupled deep transform learning, IEEE ICCV, pp.5429-5438, 2017. ,
Unpaired imageto-image translation using cycle-consistent adversarial networks, IEEE CVPR, pp.2223-2232, 2017. ,
Conditional generative adversarial nets, 2014. ,
Real-time exemplar-based face sketch synthesis, ECCV, pp.800-813, 2014. ,
Face sketch synthesis via sparse representation, IEEE ICIP, pp.2146-2149, 2010. ,
Face sketch-photo synthesis under multi-dictionary sparse representation framework, IEEE ICIG, pp.82-87, 2011. ,
Semi-coupled dictionary learning with applications to image super-resolution and photo-sketch synthesis, IEEE CVPR, pp.2216-2223, 2012. ,
A simple and fast method for face sketch synthesis, ACM ICIMCS, pp.168-171, 2016. ,
End-to-end photosketch generation via fully convolutional representation learning, ACM ICMR, pp.627-634, 2015. ,
Deep graphical feature learning for face sketch synthesis, IJCAI, pp.3574-3580, 2017. ,
Principal component analysis, 2002. ,
Nonlinear dimensionality reduction by locally linear embedding, Science, vol.290, issue.5500, pp.2323-2326, 2000. ,
Efficient sparse coding algorithms, NIPS, pp.801-808, 2007. ,
Image denoising via sparse and redundant representations over learned dictionaries, IEEE Trans. IP, vol.15, issue.12, pp.3736-3745, 2006. ,
Sparse representation for color image restoration, IEEE Trans. IP, vol.17, issue.1, pp.53-69, 2008. ,
Image deblurring and super-resolution by adaptive sparse domain selection and adaptive regularization, IEEE Trans. IP, vol.20, issue.7, pp.1838-1857, 2011. ,
Centralized sparse representation for image restoration, IEEE ICCV, pp.1259-1266, 2011. ,
Generative adversarial nets, NIPS, pp.2672-2680, 2014. ,
Least squares generative adversarial networks, IEEE ICCV, pp.2813-2821, 2017. ,
Image-to-image translation with conditional adversarial networks, IEEE CVPR, pp.1125-1134, 2017. ,
U-Net: Convolutional networks for biomedical image segmentation, MICCAI, pp.234-241, 2015. ,
Image style transfer using convolutional neural networks, IEEE CVPR, pp.2414-2423, 2016. ,
Perceptual losses for real-time style transfer and super-resolution, ECCV, pp.694-711, 2016. ,
A lightened cnn for deep face representation, Computer Science, 2015. ,
The FaceSketchID system: Matching facial composites to mugshots, IEEE Trans. TIFS, vol.9, issue.12, pp.2248-2263, 2014. ,
Memetically optimized mcwld for matching sketches with digital face images, IEEE Trans. IFS, vol.7, issue.5, pp.1522-1535, 2012. ,
Labeled faces in the wild: A database for studying face recognition in unconstrained environments, 2007. ,
Morph: A longitudinal image database of normal adult age-progression, IEEE FG, pp.341-345, 2006. ,
Facial attributes guided deep sketch-to-photo synthesis, IEEE WACV Workshops, pp.1-8, 2018. ,
Image quality assessment: from error visibility to structural similarity, Trans. IP, vol.13, issue.4, pp.600-612, 2004. ,
Improved techniques for training gans, NIPS, pp.2234-2242, 2016. ,
Photo-realistic single image super-resolution using a generative adversarial network, IEEE CVPR, pp.4681-4690, 2017. ,
Recognizing composite sketches with digital face images via ssd dictionary, IEEE IJCB, pp.1-6, 2014. ,
