Type-Based Complexity Analysis of Probabilistic Functional Programs
We show that complexity analysis of probabilistic higher-order functional programs can be carried out composi-tionally by way of a type system. The introduced type system is a significant extension of refinement types. On the one hand, the presence of probabilistic effects requires adopting a form of dynamic distribution type, subject to a coupling-based subtyping discipline. On the other hand, recursive definitions are proved terminating by way of Lyapunov ranking functions. We prove not only that the obtained type system, called RPCF, provides a sound methodology for average case complexity analysis, but also that it is extensionally complete, in the sense that any average case polytime Turing machines can be encoded as a term typable in RPCF.
