Journal articles
ColorMapGAN: Unsupervised Domain Adaptation for Semantic Segmentation Using Color Mapping Generative Adversarial Networks
Onur Tasar 1 S L Happy 2 Yuliya Tarabalka 1 Pierre Alliez 1
1 TITANE - Geometric Modeling of 3D Environments
CRISAM - Inria Sophia Antipolis - Méditerranée
2 STARS - Spatio-Temporal Activity Recognition Systems
Abstract : Due to the various reasons such as atmospheric effects and differences in acquisition, it is often the case that there exists a large difference between spectral bands of satellite images collected from different geographic locations. The large shift between spectral distributions of training and test data causes the current state of the art supervised learning approaches to output unsatisfactory maps. We present a novel semantic segmentation framework that is robust to such shift. The key component of the proposed framework is Color Mapping Generative Adversarial Networks (ColorMapGAN), which can generate fake training images that are semantically exactly the same as training images, but whose spectral distribution is similar to the distribution of the test images. We then use the fake images and the ground-truth for the training images to fine-tune the already trained classifier. Contrary to the existing Generative Adversarial Networks (GANs), the generator in ColorMapGAN does not have any convolutional or pooling layers. It learns to transform the colors of the training data to the colors of the test data by performing only one element-wise matrix multiplication and one matrix addition operations. Thanks to the architecturally simple but powerful design of ColorMapGAN, the proposed framework outperforms the existing approaches with a large margin in terms of both accuracy and computational complexity.
Complete list of metadata
Cited literature [71 references]  Display  Hide  Download
https://hal.inria.fr/hal-02382155
Contributor : Onur Tasar Connect in order to contact the contributor
Submitted on : Wednesday, November 27, 2019 - 9:13:57 AM
Last modification on : Saturday, June 25, 2022 - 11:40:59 PM
File
colormapgan.pdf
Identifiers
  • HAL Id : hal-02382155, version 1
Citation
Onur Tasar, S L Happy, Yuliya Tarabalka, Pierre Alliez. ColorMapGAN: Unsupervised Domain Adaptation for Semantic Segmentation Using Color Mapping Generative Adversarial Networks. IEEE Transactions on Geoscience and Remote Sensing, Institute of Electrical and Electronics Engineers, In press. ⟨hal-02382155⟩
Share
Metrics
Record views
168
Files downloads
168
