U-net: Convolutional networks for biomedical image segmentation, MICCAI, pp.234-241, 2015. ,
Ternausnet: U-net with vgg11 encoder pre-trained on imagenet for image segmentation, 2018. ,
Ternausnetv2: Fully convolutional network for instance segmentation, 2018. ,
Multi-Task Deep Learning for Satellite Image Pansharpening and Segmentation, IEEE IGARSS, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02276549
High-resolution aerial image labeling with convolutional neural networks, IEEE TGRS, vol.55, issue.12, pp.7092-7103, 2017. ,
Large-scale semantic classification: outcome of the first year of inria aerial image labeling benchmark, IEEE IGARSS, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01767807
Incremental learning for semantic segmentation of large-scale remote sensing data, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01909830
, Continual Learning for Dense Labeling of Satellite Images, IEEE IGARSS, 2019.
Fcns in the wild: Pixel-level adversarial and constraint-based adaptation, 2016. ,
Learning from synthetic data: Addressing domain shift for semantic segmentation, IEEE CVPR, pp.3752-3761, 2018. ,
Image to image translation for domain adaptation, IEEE CVPR, pp.4500-4509, 2018. ,
Learning to adapt structured output space for semantic segmentation, IEEE CVPR, pp.7472-7481, 2018. ,
Domain transfer through deep activation matching, in ECCV, pp.590-605, 2018. ,
Conditional generative adversarial network for structured domain adaptation, IEEE CVPR, pp.1335-1344, 2018. ,
Maximum classifier discrepancy for unsupervised domain adaptation, IEEE CVPR, pp.3723-3732, 2018. ,
Curriculum domain adaptation for semantic segmentation of urban scenes, IEEE, pp.2020-2030, 2017. ,
Road: Reality oriented adaptation for semantic segmentation of urban scenes, IEEE CVPR, pp.7892-7901, 2018. ,
Imagenet large scale visual recognition challenge, IJCV, vol.115, issue.3, pp.211-252, 2015. ,
A fully convolutional tri-branch network (fctn) for domain adaptation, IEEE ICASSP. IEEE, pp.3001-3005, 2018. ,
Unsupervised domain adaptation for semantic segmentation via class-balanced self-training, in ECCV, pp.289-305, 2018. ,
A domain agnostic normalization layer for unsupervised adversarial domain adaptation, 2018. ,
Adversarial dropout regularization, 2017. ,
Two at once: Enhancing learning and generalization capacities via ibn-net, in ECCV, pp.464-479, 2018. ,
Penalizing top performers: Conservative loss for semantic segmentation adaptation, ECCV, pp.568-583, 2018. ,
Instance normalization: The missing ingredient for fast stylization, 2016. ,
Unpaired image-to-image translation using cycle-consistent adversarial networks, IEEE CVPR, pp.2223-2232, 2017. ,
Unsupervised image-to-image translation networks, pp.700-708, 2017. ,
Multimodal unsupervised image-to-image translation, ECCV, pp.172-189, 2018. ,
Diverse image-to-image translation via disentangled representations, in ECCV, pp.35-51, 2018. ,
, Cycada: Cycle-consistent adversarial domain adaptation, 2017.
Image style transfer using convolutional neural networks, IEEE CVPR, pp.2414-2423, 2016. ,
Preserving color in neural artistic style transfer, 2016. ,
Perceptual losses for real-time style transfer and super-resolution, ECCV, pp.694-711, 2016. ,
Texture networks: Feed-forward synthesis of textures and stylized images, ICML, vol.1, p.4, 2016. ,
Domain adaptation for the classification of remote sensing data: An overview of recent advances, IEEE Geoscience and Remote Sensing Magazine, vol.4, issue.2, pp.41-57, 2016. ,
A novel approach to the selection of spatially invariant features for the classification of hyperspectral images with improved generalization capability, IEEE TGRS, vol.47, issue.9, pp.3180-3191, 2009. ,
Kernel-based domain-invariant feature selection in hyperspectral images for transfer learning, IEEE TGRS, vol.54, issue.5, pp.2615-2626, 2015. ,
Unsupervised retraining of a maximum likelihood classifier for the analysis of multitemporal remote sensing images, IEEE TGRS, vol.39, issue.2, pp.456-460, 2001. ,
, A partially unsupervised cascade classifier for the analysis of multitemporal remote-sensing images, Pattern Recognition Letters, vol.23, issue.9, pp.1063-1071, 2002.
A multiple-cascade-classifier system for a robust and partially unsupervised updating of land-cover maps, IEEE TGRS, vol.40, issue.9, 1984. ,
Domain adaptation problems: A dasvm classification technique and a circular validation strategy, IEEE TPAMI, vol.32, issue.5, pp.770-787, 2009. ,
Active learning for domain adaptation in the supervised classification of remote sensing images, IEEE TGRS, vol.50, issue.11, pp.4468-4483, 2012. ,
Svm-based boosting of active learning strategies for efficient domain adaptation, IEEE JSTARS, vol.5, issue.5, pp.1335-1343, 2012. ,
Active multi-kernel domain adaptation for hyperspectral image classification, Pattern Recognition, vol.77, pp.306-315, 2018. ,
Learning and adapting robust features for satellite image segmentation on heterogeneous data sets, IEEE TGRS, 2019. ,
Multidimensional probability density function matching for preprocessing of multitemporal remote sensing images, IEEE TGRS, vol.46, issue.4, pp.1243-1252, 2008. ,
, Digital Image Processing, 2006.
Graph matching for adaptation in remote sensing, IEEE TGRS, vol.51, issue.1, pp.329-341, 2012. ,
Kernel principal component and maximum autocorrelation factor analyses for change detection, Image and Signal Processing for Remote Sensing XV, vol.7477, p.74770, 2009. ,
An overview of color constancy algorithms, Journal of Pattern Recognition Research, vol.1, issue.1, pp.42-54, 2006. ,
Semisupervised transfer component analysis for domain adaptation in remote sensing image classification, IEEE TGRS, vol.53, issue.7, pp.3550-3564, 2015. ,
Understanding angular effects in vhr imagery and their significance for urban land-cover model portability: A study of two multi-angle intrack image sequences, ISPRS Journal of Photogrammetry and Remote Sensing, vol.107, pp.99-111, 2015. ,
Centroid and covariance alignment-based domain adaptation for unsupervised classification of remote sensing images, IEEE TGRS, vol.57, issue.4, pp.2305-2323, 2018. ,
Nonlinear feature normalization for hyperspectral domain adaptation and mitigation of nonlinear effects, IEEE TGRS, 2019. ,
Tensor alignment based domain adaptation for hyperspectral image classification, 2018. ,
Domain adaptation with regularized optimal transport, Joint European Conference on Machine Learning and Knowledge Discovery in Databases, pp.274-289, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01018698
Optimal transport for domain adaptation, IEEE TPAMI, vol.39, issue.9, pp.1853-1865, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-02112785
Assessment of optimal transport for operational land-cover mapping using high-resolution satellite images time series without reference data of the mapping period, Remote Sensing, vol.11, issue.9, p.1047, 2019. ,
Unsupervised domain adaptation using generative adversarial networks for semantic segmentation of aerial images, Remote Sensing, vol.11, issue.11, p.1369, 2019. ,
Image-to-image translation with conditional adversarial networks, IEEE CVPR, pp.1125-1134, 2017. ,
A spatial processor model for object colour perception, Journal of the Franklin institute, vol.310, issue.1, pp.1-26, 1980. ,
Generative adversarial nets, NIPS, pp.2672-2680, 2014. ,
Unsupervised representation learning with deep convolutional generative adversarial networks, 2015. ,
Wasserstein gan, 2017. ,
Improved training of wasserstein gans, pp.5767-5777, 2017. ,
Least squares generative adversarial networks, IEEE, pp.2794-2802, 2017. ,
, Conditional generative adversarial nets, 2014.
Empirical evaluation of rectified activations in convolutional network, 2015. ,
Arbitrary style transfer in real-time with adaptive instance normalization, IEEE, pp.1501-1510, 2017. ,
Deeplab: Semantic image segmentation with deep convolutional nets, atrous convolution, and fully connected crfs, IEEE TPAMI, vol.40, issue.4, pp.834-848, 2018. ,
What is a good evaluation measure for semantic segmentation?, BMVC, vol.27, p.2013, 2013. ,
