Energy Management for Microgrids: a Reinforcement Learning Approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper presents a framework based on reinforcement learning for energy management and economic dispatch of an islanded microgrid without any forecasting module. The architecture of the algorithm is divided in two parts: a learning phase trained by a reinforcement learning (RL) algorithm on a small dataset and the testing phase based on a decision tree induced from the trained RL. An advantage of this approach is to create an autonomous agent, able to react in real-time, considering only the past. This framework was tested on real data acquired at Ecole Polytechnique in France over a long period of time, with a large diversity in the type of days considered. It showed near optimal, efficient and stable results in each situation.
Paper_Draft2.pdf (329.17 Ko) Télécharger le fichier
hal-02382232 , version 1 (12-12-2019)
Tanguy Levent, Philippe Preux, Erwan Le Pennec, Jordi Badosa, Gonzague Henri, et al.. Energy Management for Microgrids: a Reinforcement Learning Approach. ISGT-Europe 2019 - IEEE PES Innovative Smart Grid Technologies Europe, Sep 2019, Bucharest, France. pp.1-5, ⟨10.1109/ISGTEurope.2019.8905538⟩. ⟨hal-02382232⟩
464 Consultations
1490 Téléchargements
