Proximal alternating minimization and projection methods for nonconvex problems: An approach based on the Kurdyka-?ojasiewicz inequality, Mathematics of Operations Research, vol.35, issue.2, pp.438-457, 2010. ,
Exact penalty decomposition method for zero-norm minimization based on MPEC formulation, SIAM Journal on Scientific Computing, vol.36, issue.4, pp.1451-1477, 2014. ,
Iterative thresholding for sparse approximations, Journal of Fourier Analysis and Applications, vol.14, pp.629-654, 2008. ,
High density molecule localization for super-resolution microscopy using CEL0 based sparse approximation, 2017 IEEE 14th International Symposium on, pp.28-31, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01443565
Equivalent lipschitz surrogates for zero-norm and rank optimization problems, Journal of Global Optimization, pp.1-26, 2018. ,
Sub-diffraction-limit imaging by stochastic optical reconstruction microscopy (storm), Nature methods, vol.3, issue.10, p.793, 2006. ,
Quantitative evaluation of software packages for single-molecule localization microscopy, Nature methods, vol.12, issue.8, p.717, 2015. ,
A unified view of exact continuous penalties for \ell 2-\ell 0 minimization, SIAM Journal on Optimization, vol.27, issue.3, pp.2034-2060, 2017. ,
, Sparsity Constrained Minimization via Mathematical Programming with Equilibrium Constraints, 2016.
From Bernoulliian deconvolution to sparse signal restoration, IEEE Transactions on Signal Processing, vol.59, issue.10, pp.4572-2484, 2011. ,
A semidefinite representation for some minimum cardinality problems, 42nd IEEE International Conference on Decision and Control, vol.5, pp.4985-4990, 2003. ,
Research Report: Exact biconvex reformulation of the 2 ? 0 minimization problem, 2019. ,
New methods for L 2-L 0 minimization and their applications to 2D Single-Molecule Localization Microscopy, IEEE International Symposium on Biomedical Imaging, 2019. ,
