Sharp asymptotics of the first exit point density, Ann. PDE, vol.5, issue.1, 2019. ,
Jump Markov models and transition state theory: the quasi-stationary distribution approach, Faraday Discuss, vol.195, pp.469-495, 2017. ,
Mathematical foundations of accelerated molecular dynamics methods, Handbook of Materials Modeling, 2019. ,
Mathematical approaches to the problem of noise-induced exit, Stochastic Analysis, Control, Optimization and Applications, pp.269-287, 1999. ,
The exit problem for randomly perturbed dynamical systems, SIAM J. Appl. Math, vol.33, issue.2, pp.365-382, 1977. ,
A direct approach to the exit problem, SIAM J. Appl. Math, vol.50, issue.2, pp.595-627, 1990. ,
The exit problem: a new approach to diffusion across potential barriers, SIAM J. Appl. Math, vol.36, issue.3, pp.604-623, 1979. ,
On elliptic singular perturbation problems with turning points, SIAM J. Math. Anal, vol.10, issue.3, pp.447-455, 1979. ,
Elliptic perturbation of a 1st order operator with a singular point of attracting type, Indiana Univ. Math. J, vol.27, issue.6, pp.935-952, 1978. ,
Perturbed dynamical systems with an attracting singularity and weak viscosity limits in Hamilton-Jacobi equations, Trans. Am. Math. Soc, vol.317, issue.2, pp.723-748, 1990. ,
Metastability for parabolic equations with drift: part 1, Indiana Univ. Math. J, vol.64, pp.875-913, 2015. ,
Metastability for parabolic equations with drift, part II: the quasilinear case, Indiana Univ. Math. J, vol.66, issue.1, pp.315-360, 2017. ,
Random Perturbations of Dynamical Systems, 2012. ,
On the asymptotic relation between equilibrium density and exit measure in the exit problem, Stoch. Int. J. Probab. Stoch. Process, vol.12, issue.3-4, pp.303-330, 1984. ,
Recent progress on the small parameter exit problem, Stoch. Int. J. Probab. Stoch. Process, vol.20, issue.2, pp.121-150, 1987. ,
, A mathematical formalization of the parallel replica dynamics, vol.18, pp.119-146, 2012.
URL : https://hal.archives-ouvertes.fr/hal-00596161
Low temperature asymptotics for quasistationary distributions in a bounded domain, Anal. PDE, vol.8, issue.3, pp.561-628, 2015. ,
The exit from a metastable state: concentration of the exit point distribution on the low energy saddle points, 2019. ,
, Quasi-Stationary Distributions: Markov Chains, Diffusions and Dynamical Systems, 2012.
, Elliptic Partial Differential Equations of Second Order, 2001.
, Partial Differential Equations, vol.19, 2010.
Riemannian Geometry and Geometric Analysis, 2017. ,
Quantitative analysis of metastability in reversible diffusion processes via a Witten complex approach: the case with boundary, Mém. Soc. Math. Fr, p.105, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-00002744
Exit event from a metastable state and Eyring-Kramers law for the overdamped Langevin dynamics, Springer Proceedings in Mathematics & Statistics, p.1696187, 2017. ,
Repartition of the quasi-stationary distribution and first exit point density for a double-well potential, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02017327
Analyse spectrale et analyse semi-classique pour la métastabilité en dynamique moléculaire, 2017. ,
Tunnel effect and symmetries for Kramers-Fokker-Planck type operators, J. Inst. Math. Jussieu, vol.10, issue.3, pp.567-634, 2011. ,
Metastability in reversible diffusion processes, I: sharp asymptotics for capacities and exit times, J. Eur. Math. Soc, vol.6, issue.4, pp.399-424, 2004. ,
Metastability in reversible diffusion processes, II: precise asymptotics for small eigenvalues, J. Eur. Math. Soc, vol.7, issue.1, pp.69-99, 2005. ,
Quantitative analysis of metastability in reversible diffusion processes via a Witten complex approach, Mat. Contemp, vol.26, pp.41-85, 2004. ,
URL : https://hal.archives-ouvertes.fr/hal-00001236
Puits multiples en meécanique semi-classique IV Etude du complexe de Witten, Commun. Partial Differ. Equ, vol.10, issue.3, pp.245-340, 1985. ,
Hodge Decomposition-A Method for Solving Boundary Value Problems, Lecture Notes in Mathematics, vol.1607, 1995. ,
Supersymmetry and Morse theory, J. Differ. Geom, vol.17, issue.4, pp.661-692, 1982. ,
On the semiclassical analysis of the ground state energy of the Dirichlet Pauli operator III: magnetic fields that change sign, Lett. Math. Phys, vol.109, issue.7, pp.1533-1558, 2019. ,
, Spectral Theory and Its Applications, vol.139, 2013.
Small eigenvalues of the Neumann realization of the semiclassical Witten Laplacian, item ?id =AFST _2010 __19 _3 -4 _735 _0, pp.735-809, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-00297207
About small eigenvalues of Witten Laplacian, Pure Appl. Anal, vol.1, issue.2, pp.149-206, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02488105
Dirichlet's and Thomson's principles for non-selfadjoint elliptic operators with application to non-reversible metastable diffusion processes, Arch. Ration. Mech. Anal, vol.231, issue.2, pp.887-938, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02151370
Asymptotics of the spectral gap with applications to the theory of simulated annealing, J. Funct. Anal, vol.83, issue.2, pp.333-347, 1989. ,
Comportement de spectres d'opérateurs de Schrödinger à basse température, Bull. Sci. Math, vol.119, issue.6, pp.529-554, 1995. ,
, Trace Ideals and Their Applications, vol.35, 1979.
Small singular values of an extracted matrix of a Witten complex, CUBO, Math. J, vol.11, issue.4, pp.49-57, 2009. ,
