Aurora: a new model and architecture for data stream management, VLDB, vol.12, issue.2, pp.120-139, 2003. ,
The design of the borealis stream processing engine, CIDR, 2005. ,
Streamforce: outsourcing access control enforcement for stream data to the clouds, ACM CODASPY, pp.13-24, 2014. ,
Stream: The stanford data stream management system, 2004. ,
The cql continuous query language: semantic foundations and query execution, The VLDB Journal, vol.15, issue.2, pp.121-142, 2006. ,
Stream: The stanford data stream management system, Data Stream Management, pp.317-336, 2016. ,
Managing parallelism for stream processing in the cloud, HOTCDP Workshop, pp.1-5, 2012. ,
Optimal operator placement for distributed stream processing applications, DEBS, pp.69-80, 2016. ,
Enforcing access control over data streams, ACM SACMAT, pp.21-30, 2007. ,
Specifying access control policies on data streams, Advances in Databases: Concepts, Systems and Applications, pp.410-421, 2007. ,
A framework to enforce access control over data streams, ACM TISSEC, vol.13, issue.3, p.28, 2010. ,
Scalable sql and nosql data stores, Acm Sigmod Record, vol.39, issue.4, pp.12-27, 2011. ,
Fast heuristics for near-optimal task allocation in data stream processing over clusters, CIKM, pp.1579-1588, 2014. ,
Google's globally distributed database, ACM Transactions on Computer Systems (TOCS), vol.31, issue.3, 2013. ,
Relational cloud: A database-as-a-service for the cloud, 2011. ,
Preference-aware query optimization for decentralized database systems, ICDE, 2014. ,
Operator placement with qos constraints for distributed stream processing, CNSM, pp.1-7, 2011. ,
Twitter heron: Stream processing at scale, SIGMOD, pp.239-250, 2015. ,
Parallel data processing with mapreduce: a survey, AcM sIGMoD Record, vol.40, issue.4, pp.11-20, 2012. ,
Securing the borealis data stream engine, IEEE IDEAS, pp.137-147, 2006. ,
A security punctuation framework for enforcing access control on streaming data, ICDE, pp.406-415, 2008. ,
Fence: Continuous access control enforcement in dynamic data stream environments, ACM CODASPY, pp.243-254, 2013. ,
Privacy preservation in streaming data collection, ICPADS, pp.810-815, 2012. ,
Network-aware operator placement for stream-processing systems, ICDE, pp.49-49, 2006. ,
New tpc benchmarks for decision support and web commerce, ACM Sigmod Record, vol.29, issue.4, pp.64-71, 2000. ,
Cryptdb: protecting confidentiality with encrypted query processing, ACM SOSP, pp.85-100, 2011. ,
Solving the multi-operator placement problem in large-scale operator networks, ICCCN, pp.1-6, 2010. ,
F1: A distributed sql database that scales, vol.6, pp.1068-1079, 2013. ,
Operator placement for in-network stream query processing, SIGMOD, pp.250-258, 2005. ,
Distributed and fault-tolerant realtime computation, 2014. ,
Polystream: Cryptographically enforced access controls for outsourced data stream processing, SACMAT, vol.21, p.12, 2016. ,
Automated operator placement in distributed data stream management systems subject to user constraints, ICDEW, pp.310-316, 2014. ,
