An obstruction to small-time controllability of the bilinear Schrödinger equation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2019
In this article we discuss which controllability properties of classical Hamiltonian systems are preserved after quantization. We discuss some necessary and some sufficient conditions for small-time controllability of classical systems and quantum systems using the WKB method. In particular, we investigate the conjecture that if the classical system is not small-time controllable, then the corresponding quantum system is not small-time controllable either.
wkb_new.pdf (230.78 Ko) Télécharger le fichier
hal-02385244 , version 1 (28-11-2019)
hal-02385244 , version 2 (05-12-2019)
Ivan Beschastnyi, Ugo Boscain, Mario Sigalotti. An obstruction to small-time controllability of the bilinear Schrödinger equation. 2019. ⟨hal-02385244v1⟩
126 Consultations
166 Téléchargements
