G. Alessandrini, L. Rondi, E. Rosset, and S. Vessella, The stability for the Cauchy problem for elliptic equations, Inverse Problems, vol.25, issue.12, p.47, 2009.
M. Azaïez, F. B. Belgacem, and H. E. Fekih, On Cauchy's problem: II. Completion, regularization and approximation, Inverse Problems, vol.22, issue.4, p.1307, 2006.
F. B. Belgacem, Why is the Cauchy problem severely ill-posed? Inverse Problems, vol.23, pp.823-836, 2007.
L. Bourgeois, A mixed formulation of quasi-reversibility to solve the Cauchy problem for Laplace's equation, Inverse Problems, vol.21, issue.3, pp.1087-1104, 2005.
L. Bourgeois, About stability and regularization of ill-posed elliptic Cauchy problems: the case of C 1,1 domains, M2AN Math. Model. Numer. Anal, vol.44, issue.4, pp.715-735, 2010.
URL : https://hal.archives-ouvertes.fr/hal-00873056
L. Bourgeois and J. Dardé, About stability and regularization of ill-posed elliptic Cauchy problems: the case of Lipschitz domains, Appl. Anal, vol.89, issue.11, pp.1745-1768, 2010.
URL : https://hal.archives-ouvertes.fr/hal-00849579
L. Bourgeois and A. Recoquillay, A mixed formulation of the Tikhonov regularization and its application to inverse PDE problems, ESAIM Math. Model. Numer. Anal, vol.52, issue.1, pp.123-145, 2018.
URL : https://hal.archives-ouvertes.fr/hal-01816804
H. Brezis, Analyse fonctionnelle : théorie et applications. Editions Dunod, 1999.
E. Burman, Stabilized finite element methods for nonsymmetric, noncoercive, and ill-posed problems. Part I: Elliptic equations, SIAM J Sci Comput, vol.35, issue.6, pp.2752-2780, 2013.
E. Burman, Stabilized finite element methods for nonsymmetric, noncoercive, and ill-posed problems. Part II: Hyperbolic equations, SIAM J Sci Comput, vol.36, issue.4, pp.1911-1936, 2014.
E. Burman, A stabilized nonconforming finite element method for the elliptic Cauchy problem, Math. Comput, vol.86, issue.303, pp.75-96, 2017.
E. Burman, P. Hansbo, and M. G. Larson, Solving ill-posed control problems by stabilized finite element methods: an alternative to Tikhonov regularization, Inverse Problems, vol.34, issue.3, p.35004, 2018.
E. Burman, M. G. Larson, and L. Oksanen, Primal-dual mixed finite element methods for the elliptic Cauchy problem, SIAM J. Numer. Anal, vol.56, issue.6, pp.3480-3509, 2018.
L. Chesnel and P. Ciarlet, T-coercivity and continuous Galerkin methods: application to transmission problems with sign changing coefficients, Numer. Math, vol.124, issue.1, pp.1-29, 2013.
URL : https://hal.archives-ouvertes.fr/hal-00688862
L. Chesnel, X. Claeys, and S. A. Nazarov, A curious instability phenomenon for a rounded corner in presence of a negative material, Asymp. Anal, vol.88, issue.1, pp.43-74, 2014.
URL : https://hal.archives-ouvertes.fr/hal-00909836
L. Chesnel, X. Claeys, and S. A. Nazarov, Oscillating behaviour of the spectrum for a plasmonic problem in a domain with a rounded corner, Math. Mod. Num. Anal, vol.52, issue.4, pp.1285-1313, 2018.
URL : https://hal.archives-ouvertes.fr/hal-01240977
P. G. Ciarlet, The finite element method for elliptic problems, Studies in Mathematics and its Applications, vol.4, 1978.
M. Costabel and M. Dauge, A singularly perturbed mixed boundary value problem, Comm. Partial Differential Equations, vol.21, pp.1919-1949, 1996.
J. Dardé, Iterated quasi-reversibility method applied to elliptic and parabolic data completion problems, Inverse Probl. Imaging, vol.10, issue.2, pp.379-407, 2016.
J. Dardé, A. Hannukainen, and N. Hyvönen, An H div -based mixed quasi-reversibility method for solving elliptic Cauchy problems, SIAM J. Numer. Anal, vol.51, issue.4, pp.2123-2148, 2013.
P. Grisvard, Elliptic Problems in Nonsmooth Domains, 1985.
P. Grisvard, Singularities in boundary value problems, Recherches en Mathématiques Appliquées, vol.22
P. Masson, , 1992.
J. Hadamard, Sur les problèmes aux dérivées partielles et leur signification physique. Princeton university bulletin, pp.49-52, 1902.
A. , Il'in. Matching of asymptotic expansions of solutions of boundary value problems, Translations of Mathematical Monographs, vol.102, 1992.
T. Johansson, An iterative procedure for solving a Cauchy problem for second order elliptic equations, Math. Nachr, vol.272, pp.46-54, 2004.
A. Kirsch, The Robin problem for the Helmholtz equation as a singular perturbation problem, Numer. Func. Anal. Opt, vol.8, issue.1-2, pp.1-20, 1985.
M. V. Klibanov and F. Santosa, A computational quasi-reversibility method for Cauchy problems for Laplace's equation, SIAM J. Appl. Math, vol.51, issue.6, pp.1653-1675, 1991.
V. A. Kondratiev, Boundary-value problems for elliptic equations in domains with conical or angular points, Trans. Moscow Math. Soc, vol.16, pp.227-313, 1967.
V. A. Kozlov, V. G. Maz'ya, and J. Rossmann, Elliptic Boundary Value Problems in Domains with Point Singularities, Mathematical Surveys and Monographs, vol.52, 1997.
V. A. Kozlov, V. G. Maz'ya, and J. Rossmann, Spectral problems associated with corner singularities of solutions to elliptic equations, Mathematical Surveys and Monographs, vol.85, 2001.
R. Lattès and J. Lions, Méthode de quasi-réversibilité et applications, Travaux et Recherches Mathématiques, 1967.
V. G. Maz'ya, S. A. Nazarov, and B. A. Plamenevski?, Asymptotic theory of elliptic boundary value problems in singularly perturbed domains, vol.1, 2000.
V. G. Maz'ya and B. A. Plamenevski?, On the coefficients in the asymptotics of solutions of elliptic boundary value problems with conical points, Engl. transl. Amer. Math. Soc. Transl, vol.76, pp.57-89, 1977.
S. A. Nazarov and B. A. Plamenevski?, Elliptic problems in domains with piecewise smooth boundaries, Expositions in Mathematics. De Gruyter, vol.13, 1994.
S. A. Nazarov and N. Popoff, Self-adjoint and skew-symmetric extensions of the Laplacian with singular Robin boundary condition, C. R. Acad. Sci. Paris, Ser. I, vol.356, issue.9, pp.927-932, 2018.
S. A. Nazarov, N. Popoff, and J. Taskinen, Plummeting and blinking eigenvalues of the Robin Laplacian in a cuspidal domain, 2018.
S. Nicaise, Regularity of the solutions of elliptic systems in polyhedral domains, Bull. Belg. Math. Soc. Simon Stevin, vol.4, issue.3, pp.411-429, 1997.
L. E. Payne, Bounds in the Cauchy problem for the Laplace equation, Arch. Ration. Mech. Anal, vol.5, issue.1, pp.35-45, 1960.
L. E. Payne, On a priori bounds in the Cauchy problem for elliptic equations, SIAM J. Math. Anal, vol.1, issue.1, pp.82-89, 1970.
K. Phung, Remarques sur l'observabilité pour l'équation de Laplace, ESAIM Control Optim. Calc. Var, vol.9, pp.621-635, 2003.
