The electric vehicle routing problem with capacitated charging stations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Transportation Science Année : 2022
Much of the existing research on electric vehicle routing problems (E-VRPs) assumes that the charging stations (CSs) can simultaneously charge an unlimited number of electric vehicles, but this is not the case. In this research, we investigate how to model and solve E-VRPs taking into account these capacity restrictions. In particular, we study an E-VRP with non-linear charging functions, multiple charging technologies, en route charging, and variable charging quantities, while explicitly accounting for the capacity of CSs expressed in the number of chargers. We refer to this problem as the E-VRP with non-linear charging functions and capacitated stations (E-VRP-NL-C). This problem advances the E-VRP literature by considering the scheduling of charging operations at each CS. We first introduce two mixed integer linear programming formulations showing how CS capacity constraints can be incorporated into E-VRP models. We then introduce an algorithmic framework to the E-VRP-NL-C, that iterates between two main components: a route generator and a solution assembler. The route generator uses an iterated local search algorithm to build a pool of high-quality routes. The solution assembler applies a branch-and-cut algorithm to select a subset of routes from the pool. We report on computational experiments comparing four different assembly strategies on a large and diverse set of instances. Our results show that our algorithm deals with the CS capacity constraints effectively. Furthermore, considering the well-known uncapacitated version of the E-VRP-NL-C, our solution method identifies new best-known solutions for 80 out of 120 instances.
The_electric_vehicle_routing_problem_with_capacitated_charging_stations_v3.pdf (647.96 Ko) Télécharger le fichier
hal-02386167 , version 1 (29-11-2019)
hal-02386167 , version 2 (15-02-2021)
hal-02386167 , version 3 (31-12-2021)
Aurélien Froger, Ola Jabali, Jorge E. Mendoza, Gilbert Laporte. The electric vehicle routing problem with capacitated charging stations. Transportation Science, 2022, 56 (2), pp.460-482. ⟨10.1287/trsc.2021.1111⟩. ⟨hal-02386167v3⟩
1033 Consultations
1731 Téléchargements
