Numerical continuation methods: an introduction, 20 Sampling and Meshing Submanifolds, vol.502, 1990. ,
Sampling from a manifold. 551 IMS Collections, 2012. ,
Con-553 tour tracing by piecewise linear approximations, ACM Transactions on Graphics (TOG), vol.554, issue.4, pp.389-423, 1990. ,
A course in triangulations for solving equations with deformations, Lecture Notes in Economics and Mathematical Systems, vol.556, p.234, 1984. ,
What happens to a manifold under a bi-lipschitz 558 map?, Discrete & Computational Geometry, vol.57, issue.3, pp.641-673, 2017. ,
Loopless algorithms for generating permutations, combinations, and other 561 combinatorial configurations, Journal of the ACM (JACM), vol.20, issue.3, pp.500-513, 1973. ,
Simplizialzerlegungen von beschrankter flachheit, Annals of Mathemat-563 ics, pp.580-582, 1942. ,
Comparison theorems for the volumes of tubes as generalizations of the weyl 565 tube formula, Topology, vol.21, issue.2, pp.201-228, 1982. ,
, 27 GUDHI Project. GUDHI Editorial Board
Nonlinear normal modes and spectral submanifolds: 569 existence, uniqueness and use in model reduction, Nonlinear dynamics, vol.86, issue.3, p.2016 ,
Reflection groups and Coxeter groups, vol.29, 1992. ,
Manifold meshing using Coxeter triangulations, Uni-574 versité Côte d'Azur, 2019. ,
Planning Algorithms, vol.576, 2006. ,
URL : https://hal.archives-ouvertes.fr/hal-01993243
Marching cubes: A high resolution 3d surface 578 construction algorithm, ACM siggraph computer graphics, vol.21, pp.163-169 ,
On the permutahedron and the quadratic placement problem ,
, Philips Journal of Research, vol.46, issue.6, pp.267-292, 1992.
Topology 583 of cyclo-octane energy landscape, The journal of chemical physics, vol.132, issue.23, p.234115, 2010. ,
Simplicial isosurfacing in arbitrary dimension and codimension, Journal of 585 Computational Physics, vol.190, issue.1, pp.295-310, 2003. ,
Sampling hypersurfaces through diffusion, 587 12th Intl. Workshop on Randomization and Computation (RANDOM), 2008. ,
On Stirling numbers of the second kind, Journal of Combin-589 atorial Theory, vol.7, pp.116-121, 1969. ,
Gray codes for set partitions and restricted growth 593 tails, Australasian J. Combinatorics, vol.10, pp.85-96, 1994. ,
The computation of fixed points and applications, Lecture 595 Notes in Economics and Mathematical Systems, vol.124, 1976. ,
A note on random projections for preserving paths on a manifold, 2011. ,
Loop-free sequencing of bounded integer compositions, Journal, p.599 ,
, Combinatorial Mathematics and Combinatorial Computing, vol.33, pp.323-345, 2000.
, , vol.00, p.21
Isosurfaces: geometry, topology, and algorithms, vol.601, p.2013 ,
On the volume of tubes, American Journal of Mathematics, vol.61, issue.2, p.603 ,
On C 1 -complexes, Annals of Mathematics, vol.41, issue.4, p.605, 1940. ,
Geometric Integration Theory, p.607, 1957. ,
, Lectures on Polytopes. Graduate Texts in Mathematics, vol.608, 2012.
