Proof Nets for First-Order Additive Linear Logic - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present canonical proof nets for first-order additive linear logic, the fragment of linear logic with sum, product, and first-order universal and existential quantification. We present two versions of our proof nets. One, witness nets, retains explicit witnessing information to existential quantification. For the other, unification nets, this information is absent but can be reconstructed through unification. Unification nets embody a central contribution of the paper: first-order witness information can be left implicit, and reconstructed as needed. Witness nets are canonical for first-order additive sequent calculus. Unification nets in addition factor out any inessential choice for existential witnesses. Both notions of proof net are defined through coalescence, an additive counterpart to multiplicative contractibility, and for witness nets an additional geometric correctness criterion is provided. Both capture sequent calculus cut-elimination as a one-step global composition operation. 2012 ACM Subject Classification Theory of computation → Proof theory; Theory of computation → Linear logic
LIPIcs-FSCD-2019-22.pdf (683.77 Ko) Télécharger le fichier
hal-02386942 , version 1 (29-11-2019)
Willem Heijltjes, Dominic J D Hughes, Lutz Strassburger. Proof Nets for First-Order Additive Linear Logic. FSCD 2019 - 4th International Conference on Formal Structures for Computation and Deduction, Jun 2019, Dortmund, Germany. pp.22:1-22:22, ⟨10.4230/LIPIcs.FSCD.2019.22⟩. ⟨hal-02386942⟩
46 Consultations
75 Téléchargements
