Preliminary evaluation of haptic guidance for pre-positioning a comanipulated needle - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In minimally-invasive procedures like biopsy, the physician has to insert a needle into the tissues of a patient to reach a target. Currently, this task is mostly performed manually. This can result in a large nal positioning error of the tip that might lead to misdiagnosis and inadequate treatment. In this paper, we present 5 haptic guides to assist the clinical gesture of needle insertion. Those guides were evaluated through a preliminary user study involving two physicians, both experts in needle manipulation.
2019_gurnel_Surgetica.pdf (866.45 Ko) Télécharger le fichier
hal-02387214 , version 1 (29-11-2019)
  • HAL Id : hal-02387214 , version 1
Hadrien Gurnel, Maud Marchal, Laurent Launay, Luc Beuzit, Alexandre Krupa. Preliminary evaluation of haptic guidance for pre-positioning a comanipulated needle. SURGETICA 2019, Jun 2019, Rennes, France. pp.1-3. ⟨hal-02387214⟩
69 Consultations
131 Téléchargements
