Conference papers
Pushdown Automata and Constant Height: Decidability and Bounds
Abstract : It cannot be decided whether a pushdown automaton accepts using constant pushdown height, with respect to the input length, or not. Furthermore, in the case of acceptance in constant height, the height cannot be bounded by any recursive function in the size of the description of the machine. In contrast, in the restricted case of pushdown automata over a one-letter input alphabet, i.e., unary pushdown automata, the above property becomes decidable. Moreover, if the height is bounded by a constant in the input length, then it is at most exponential with respect to the size of the description of the pushdown automaton. This bound cannot be reduced. Finally, if a unary pushdown automaton uses nonconstant height to accept, then the height should grow at least as the logarithm of the input length. This bound is optimal.
Document type :
Conference papers
Complete list of metadata
Cited literature [15 references]  Display  Hide  Download
https://hal.inria.fr/hal-02387302
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Friday, November 29, 2019 - 4:36:25 PM
Last modification on : Wednesday, December 8, 2021 - 9:22:07 AM
File
480958_1_En_20_Chapter.pdf
Identifiers
Citation
Giovanni Pighizzini, Luca Prigioniero. Pushdown Automata and Constant Height: Decidability and Bounds. 21th International Conference on Descriptional Complexity of Formal Systems (DCFS), Jul 2019, Košice, Slovakia. pp.260-271, ⟨10.1007/978-3-030-23247-4_20⟩. ⟨hal-02387302⟩
Share
Metrics
Record views
21
Files downloads
4
