Shape turnpike for linear parabolic PDE models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Systems and Control Letters Année : 2020
We introduce and study the turnpike property for time-varying shapes, within the viewpoint of optimal control. We focus here on second-order linear parabolic equations where the shape acts as a source term and we seek the optimal time-varying shape that minimizes a quadratic criterion. We first establish existence of optimal solutions under some appropriate sufficient conditions. We then provide necessary conditions for optimality in terms of adjoint equations and, using the concept of strict dissipativity, we prove that state and adjoint satisfy the measure-turnpike property, meaning that the extremal time-varying solution remains essentially close to the optimal solution of an associated static problem. We show that the optimal shape enjoys the exponential turnpike property in term of Hausdorff distance for a Mayer quadratic cost. We illustrate the turnpike phenomenon in optimal shape design with several numerical simulations.
shapeturnpike.pdf (1.13 Mo) Télécharger le fichier
hal-02388972 , version 1 (02-12-2019)
hal-02388972 , version 2 (19-06-2020)
Gontran Lance, Emmanuel Trélat, Enrique Zuazua. Shape turnpike for linear parabolic PDE models. Systems and Control Letters, 2020, 142, pp.104733. ⟨10.1016/j.sysconle.2020.104733⟩. ⟨hal-02388972v2⟩
144 Consultations
74 Téléchargements
