The supersingular isogeny problem in genus 2 and beyond - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Craig Costello
  • Fonction : Auteur
  • PersonId : 987506
Let $A/\overline{\mathbb{F}}_p$ and $A'/\overline{\mathbb{F}}_p$ be supersingular principally polarized abelian varieties of dimension $g>1$. For any prime $\ell \ne p$, we give an algorithm that finds a path $\phi \colon A \rightarrow A'$ in the $(\ell, \dots , \ell)$-isogeny graph in $\widetilde{O}(p^{g-1})$ group operations on a classical computer, and $\widetilde{O}(\sqrt{p^{g-1}})$ calls to the Grover oracle on a quantum computer. The idea is to find paths from $A$ and $A'$ to nodes that correspond to products of lower dimensional abelian varieties, and to recurse down in dimension until an elliptic path-finding algorithm (such as Delfs--Galbraith) can be invoked to connect the paths in dimension $g=1$. In the general case where $A$ and $A'$ are any two nodes in the graph, this algorithm presents an asymptotic improvement over all of the algorithms in the current literature. In the special case where $A$ and $A'$ are a known and relatively small number of steps away from each other (as is the case in higher dimensional analogues of SIDH), it gives an asymptotic improvement over the quantum claw finding algorithms and an asymptotic improvement over the classical van Oorschot--Wiener algorithm.
pq.pdf (271.56 Ko) Télécharger le fichier
hal-02389073 , version 1 (02-12-2019)
hal-02389073 , version 2 (27-01-2020)
Craig Costello, Benjamin Smith. The supersingular isogeny problem in genus 2 and beyond. PQCrypto 2020 - 11th International Conference on Post-Quantum Cryptography, Apr 2020, Paris, France. ⟨hal-02389073v2⟩
215 Consultations
372 Téléchargements
