Are fpgas suitable for edge computing?" in HotEdge, vol.18, pp.1-6 ,
, , pp.147-156
Apache flink: Stream analytics at scale, IC2EW'16, pp.193-193 ,
, Spark streaming, 2010.
Business process analytics and big data systems: A roadmap to bridge the gap, IEEE Access, vol.6, pp.77-308, 2018. ,
Lavea: Latency-aware video analytics on edge computing platform, ICDCS'17, pp.2573-2574 ,
Real-time video analytics: The killer app for edge computing, Computer, vol.50, issue.10, pp.58-67, 2017. ,
Smartcityware: A serviceoriented middleware for cloud and fog enabled smart city services, IEEE Access, vol.5, pp.17-576, 2017. ,
Datadriven stream processing at the edge, ICFEC'17, pp.31-40 ,
F-mstorm: Feedback-based online distributed mobile stream processing, SEC'18, pp.273-285 ,
, Apache edgent
Spanedge: Towards unifying stream processing over central and near-the-edge data centers, SEC'16, pp.168-178 ,
ECHO: an adaptive orchestration platform for hybrid dataflows across cloud and edge, CoRR, 2017. ,
Turbostream: Towards low-latency data stream processing, ICDCS'18, pp.983-993 ,
Hardware acceleration landscape for distributed realtime analytics: Virtues and limitations, ICDCS'17, pp.1938-1948 ,
A survey on reconfigurable accelerators for cloud computing, FPL'16, pp.1-10 ,
Understanding performance differences of fpgas and gpus, FCCM'18, pp.93-96 ,
A reconfigurable fabric for accelerating largescale datacenter services, pp.13-24 ,
Hc-cart: A parallel system implementation of data mining classification and regression tree (cart) algorithm on a multi-fpga system, ACM Trans. Archit. Code Optim, vol.9, issue.4, p.25, 2013. ,
Foregraph: Exploring large-scale graph processing on multi-fpga architecture, FPGA'17, pp.217-226 ,
Throughputoptimized opencl-based fpga accelerator for large-scale convolutional neural networks, FPGA'16, pp.16-25 ,
Optimizing fpga-based accelerator design for deep convolutional neural networks, FPGA'15, pp.161-170 ,
Leveraging reconfigurable computing in distributed real-time computation systems, EDBT/ICDT Workshops, pp.1-6, 2016. ,
An fpgabased low-latency network processing for spark streaming, BigData'17, pp.2410-2415 ,
Programming and runtime support to blaze fpga accelerator deployment at datacenter scale, pp.456-469 ,
The case for vm-based cloudlets in mobile computing, IEEE Pervasive Computing, vol.8, issue.4, pp.14-23, 2009. ,
Fog computing: Platform and applications, pp.73-78 ,
Fpga architecture: Survey and challenges, Foundations and Trends in Electronic Design Automation, vol.2, issue.2, pp.135-253, 2008. ,
Implementation of dynamicrange enhancement and super-resolution algorithms for medical image processing, pp.181-184 ,
Acceleration of kmeans algorithm using altera sdk for opencl, ACM Trans. Reconfigurable Technol. Syst, vol.10, issue.1, pp.1-6, 2016. ,
, Opencl overview
, Intel fpga sdk for opencl
Mobile storm: Distributed real-time stream processing for mobile clouds, pp.139-145 ,
Symbiosis: Sharing mobile resources for stream processing, ISCC'14, pp.1-6 ,
Mobistreams: A reliable distributed stream processing system for mobile devices, IPDPS'14, pp.51-60 ,
Large scale stream analytics using a resource-constrained edge, pp.135-139 ,
Dart: Fast and efficient distributed stream processing framework for internet of things, ETRI Journal, vol.39, issue.2, pp.202-212, 2017. ,
Amino -a distributed runtime for applications running dynamically across device, pp.361-366 ,
Rededge: A novel architecture for big data processing in mobile edge computing environments, Journal of Sensor and Actuator Networks, vol.6, issue.3, pp.1-17, 2017. ,
Chive: Bandwidth optimized continuous querying in distributed clouds, IEEE Transactions on Cloud Computing, vol.3, issue.2, pp.219-232, 2015. ,
Latency-Aware Placement of Data Stream Analytics on Edge Computing, ICSOC'18, pp.215-229 ,
URL : https://hal.archives-ouvertes.fr/hal-01875936
A data stream processing optimisation framework for edge computing applications, ISOR-C'18, pp.91-98 ,
URL : https://hal.archives-ouvertes.fr/hal-01862063
Scale-up vs scale-out for hadoop: Time to rethink?, vol.20, pp.1-20 ,
Fpmr: Mapreduce framework on fpga, FPGA'10, pp.93-102 ,
Accelerating machine learning kernel in hadoop using fpgas, CCGrid'15, pp.1151-1154 ,
Melia: A mapreduce framework on opencl-based fpgas, IEEE Transactions on Parallel and Distributed Systems, vol.27, issue.12, pp.3547-3560, 2016. ,
When apache spark meets fpgas: A case study for next-generation dna sequencing acceleration, Hot-Cloud'16, pp.64-70 ,
Accelerating apache spark with fpgas, Concurrency and Computation Practice and Experience, vol.31, issue.2, p.4222, 2017. ,
Haas: Cloud-based real-time data analytics with heterogeneity-aware scheduling, ICDCS'18, pp.1017-1028 ,
, Apache hadoop yarn
, Apache mesos
From JVM to FP-GA: Bridging abstraction hierarchy via optimized deep pipelining, pp.1-6 ,
Presto: Distributed machine learning and graph processing with sparse matrices, pp.197-210 ,
