New interface
Poster communications
Estimation of reference curves for fetal weight
Abstract : OBJECTIVES Reference or standard curves are required in many biomedical problems. Values which lie outside the limits of these reference curves may indicated the presence of disorder. Data are from the French EDEN mother-child cohort [1]. We are studying fetal weight (in grammes) that depends on the gestional age (GA) in the second and the third trimesters of mother's pregnancy. Some classical parametric and semi-parametric methods as polynomial [2][3] and LMS method [4][5] or nonparametric methods as kernel estimation [6] are used to construct these curves. However, some of them requires strong assumptions.
Document type :
Complete list of metadata
https://hal.inria.fr/hal-02389157
Contributor : Sandie Ferrigno Connect in order to contact the contributor
Submitted on : Monday, December 2, 2019 - 1:33:36 PM
Last modification on : Saturday, June 25, 2022 - 7:44:18 PM
Long-term archiving on: : Tuesday, March 3, 2020 - 7:40:28 PM
File
poster.pdf
Identifiers
  • HAL Id : hal-02389157, version 1
Citation
Sandie Ferrigno, Myriam Maumy-Bertrand. Estimation of reference curves for fetal weight. CMStatistics 2019, Dec 2019, London, United Kingdom. ⟨hal-02389157⟩
Share
Metrics
Record views
67
Files downloads
120
