Bug characteristics in open source software, Empirical Software Engineering, vol.19, issue.6, pp.1665-1705, 2014. ,
, Fuzzing
, Syzkaller: a kernel fuzzer
, Bugs found by syzkaller
DIFUZE: interface aware fuzzing for kernel drivers, Proceedings of the 24th International Conference on Computer and Communications Security (CCS, pp.2123-2138, 2017. ,
Charm: facilitating dynamic analysis of device drivers of mobile systems, Proceedings of the 27th USENIX Security Symposium, pp.291-307, 2018. ,
RAZZER: finding kernel race bugs through fuzzing, Proceedings of the 40th IEEE Symposium on Security and Privacy, pp.279-293, 2019. ,
Hector: detecting resource-release omission faults in error-handling code for systems software, Proceedings of the 43rd International Conference on Dependable Systems and Networks (DSN), pp.1-12, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00918079
An approach to improving the structure of error-handling code in the Linux kernel, Proceedings of the 2011 International Conference on Languages, Compilers, and Tools for Embedded Systems (LCTES), pp.41-50, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-01286601
Understanding modern device drivers, Proceedings of the 17th International Conference on Architectural Support for Programming Languages and Operating Systems (ASPLOS), pp.87-98, 2012. ,
PeriScope: an effective probing and fuzzing framework for the hardware-OS boundary, Proceedings of the 26th Network and Distributed Systems Security Symposium (NDSS), pp.1-15, 2019. ,
Software fault injection and its application in distributed systems, Proceedings of the 23rd International Symposium on Fault-Tolerant Computing (FTCS), pp.208-217, 1993. ,
, Linux fault injection capabilities infrastructure
Automatic fault injection for driver robustness testing, Proceedings of the 2015 International Symposium on Software Testing and Analysis (ISSTA), pp.361-372, 2015. ,
Device driver fault simulation using KEDR, International Journal of Advanced Research in Computer Engineering and Technology, pp.580-584, 2012. ,
Testing error handling code in device drivers using characteristic fault injection, Proceedings of 2016 USENIX Annual Technical Conference, pp.635-647, 2016. ,
, LLVM compiler infrastructure
, Commit 471b83bd8bbe: forbid enslaving team device to itself in the team driver
, Commit cbcc607e1842: fix double free in error path in the team driver
, Linux kernel coding style
Robustness testing of the Windows DDK, Proceedings of the 37th International Conference on Dependable Systems and Networks (DSN), pp.554-564, 2007. ,
, Clang: a LLVM-based compiler for C/C++
, The kernel address sanitizer
, The kernel memory leak detector
, Commit 5bce256f0b52: usb: xhci: Fix a potential null pointer dereference
Effective data-race detection for the kernel, Proceedings of the 9th International Symposium on Operating Systems Design and Implementation (OSDI), pp.151-162, 2010. ,
How smart is intelligent fuzzing or how stupid is dumb fuzzing?, 2007. ,
, American Fuzzy Lop (AFL)
Coverage-based greybox fuzzing as markov chain, IEEE Transactions on Software Engineering (TSE), vol.45, pp.489-506, 2017. ,
CollAFL: path sensitive fuzzing, Proceedings of the 39th IEEE Symposium on Security and Privacy, pp.679-696, 2018. ,
Perffuzz: automatically generating pathological inputs, Proceedings of the 27th International Symposium on Software Testing and Analysis (ISSTA), pp.254-265, 2018. ,
Learn&Fuzz: machine learning for input fuzzing, Proceedings of the 32nd International Conference on Automated Software Engineering (ASE, pp.50-59, 2017. ,
Skyfire: data-driven seed generation for fuzzing, Proceedings of the 38th IEEE Symposium on Security and Privacy, pp.579-594, 2017. ,
VUzzer: application-aware evolutionary fuzzing, Proceedings of the 24th Network and Distributed Systems Security Symposium (NDSS, pp.1-14, 2017. ,
Directed greybox fuzzing, Proceedings of the 24th International Conference on Computer and Communications Security (CCS, pp.2329-2344, 2017. ,
MoonShine: optimizing OS fuzzer seed selection with trace distillation, Proceedings of the 27th USENIX Security Symposium, pp.729-743, 2018. ,
kAFL: hardware-assisted feedback fuzzing for OS kernels, Proceedings of the 26th USENIX Security Symposium, pp.167-182, 2017. ,
Fuzzing Wi-Fi drivers to locate security vulnerabilities, Proceedings of the 7th European Dependable Computing Conference (EDCC), pp.110-119, 2008. ,
Testing of Java web services for robustness, Proceedings of the 2004 International Symposium on Software Testing and Analysis (ISSTA), pp.23-34, 2004. ,
PREFAIL: a programmable tool for multiple-failure injection, Proceedings of the 26th International Conference on Object Oriented Programming Systems Languages and Applications (OOPSLA), pp.171-188, 2011. ,
LFI: a practical and general librarylevel fault injector, Proceedings of the 39th International Conference on Dependable Systems and Networks, pp.379-388, 2009. ,
Bytecode fault injection for Java software, Journal of Systems and Software (JSS), vol.81, issue.11, pp.2034-2043, 2008. ,
Fast black-box testing of system recovery code, Proceedings of the 7th European Conference on Computer Systems (EuroSys), pp.281-294, 2012. ,
EDFI: A dependable fault injection tool for dependability benchmarking experiments, Proceedings of the 19th Pacific Rim Symposium on Dependable Computing, pp.31-40, 2013. ,
Amplifying tests to validate exception handling code: an extended study in the mobile application domain, ACM Transactions on Software Engineering and Methodology (TOSEM), vol.23, issue.4, p.32, 2014. ,
Do injected faults cause real failures? a case study of Linux, Proceedings of the 25th International Symposium on Software Reliability Engineering Workshops, pp.174-179, 2014. ,
An empirical study of injected versus actual interface errors, Proceedings of the 2014 International Symposium on Software Testing and Analysis (ISSTA), pp.397-408, 2014. ,
On fault representativeness of software fault injection, IEEE Transactions on Software Engineering (TSE), vol.39, issue.1, pp.80-96, 2013. ,
Representativeness analysis of injected software faults in complex software, Proceedings of the 40th International Conference on Dependable Systems and Networks (DSN), pp.437-446, 2010. ,
On the impact of injection triggers for OS robustness evaluation, Proceedings of the 18th International Symposium on Software Reliability Engineering, pp.127-126, 2007. ,
, On the selection of error model(s) for OS robustness evaluation, Proceedings of the 37th International Conference on Dependable Systems and Networks (DSN), pp.502-511, 2007.
PF-Miner: a practical paired functions mining method for Android kernel in error paths, Journal of Systems and Software (JSS), vol.121, pp.234-246, 2016. ,
EIO: error handling is occasionally correct, Proceedings of the 6th International Conference on File and Storage Technologies (FAST), pp.207-222, 2008. ,
Mining exception-handling rules as sequence association rules, Proceedings of the 31st International Conference on Software Engineering, pp.496-506, 2009. ,
Automatically detecting error handling bugs using error specifications, Proceedings of the 25th USENIX Security Symposium, pp.345-362, 2016. ,
