Numerical methods for the discretization of random fields by means of the karhunen-loève expansion, Computer Methods in Applied Mechanics and Engineering, vol.271, pp.109-129, 2014. ,
Gaussian Processes for Machine Learning, 2006. ,
Real-gas effects in organic rankine cycle turbine nozzles, Journal of Propulsion and Power, vol.24, issue.2, pp.282-294, 2008. ,
Mesh deformation based on radial basis function interpolation, Computers & structures, vol.85, pp.784-795, 2007. ,
Optimal design and tolerancing of compressor blades subject to manufacturing variability, 16th AIAA Non-Deterministic Approaches Conference, p.1008, 2014. ,
A tutorial on bayesian optimization of expensive cost functions, with application to active user modeling and hierarchical reinforcement learning, 2010. ,
Performance optimizations for scalable implicit {RANS} calculations with {SU2}, Computers & Fluids, vol.129, pp.146-158, 2016. ,
Curves and Surfaces for CAGD: A Practical Guide, p.10, 2002. ,
Nonreflecting boundary conditions for euler equation calculations, AIAA journal, vol.28, issue.12, pp.2050-2058, 1990. ,
The choice of working fluid: the most important step for a successful organic rankine cycle (and an efficient turbine), Second International Seminar on ORC Power Systems, pp.7-8, 2013. ,
Optimization of organic rankine cycle power systems considering multistage axial turbine design, Applied Energy, vol.209, pp.339-354, 2018. ,
High-fidelity shape-optimization of non-conventional turbomachinery by surrogate evolutionary strategies, Journal of Turbomachinery, vol.141, issue.8, p.81010, 2019. ,
Robust adjoint-based shape optimization of supersonic turbomachinery cascades, ASME Turbo Expo 2014: Turbine Technical Conference and Exposition, pp.2-39, 2014. ,
Adjoint method for shape optimization in real-gas flow applications, ASME Journal of Engineering for Gas Turbines and Power, vol.137, issue.3, 2015. ,
Optimization of an orc supersonic nozzle under epistemic uncertainties due to turbulence models, GPPS, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-01982227
Impact of geometric, operational, and model uncertainties on the non-ideal flow through a supersonic orc turbine cascade, vol.169, pp.213-227, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-01982234
Fully turbulent discrete adjoint solver for non-ideal compressible flow applications, Journal of the Global Power and Propulsion Society, vol.1, p.1, 2017. ,
Extension of the SU2 open source CFD code to the simulation of turbulent flows of fluids modelled with complex thermophysical laws, Number AIAA Paper, pp.2015-2760, 2015. ,
