Multi-Valued Expression Analysis for Collective Checking - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Determining if a parallel program behaves as expected on any execution is challenging due to non-deterministic executions. Static analyses help to detect all execution paths that can be executed concurrently by identifying multi-valued expressions, i.e. expressions evaluated differently among processes. This can be used to find collective errors in parallel programs. In this paper, we propose a new method that combines a control-flow analysis with a multi-valued expressions detection to find such errors. We implemented our method in the PARCOACH framework and successfully analyzed parallel applications using MPI, OpenMP, UPC and CUDA.
article_EuroPar.pdf (639.36 Ko) Télécharger le fichier
hal-02390025 , version 1 (02-12-2019)
  • HAL Id : hal-02390025 , version 1
Pierre Huchant, Emmanuelle Saillard, Denis Barthou, Patrick Carribault. Multi-Valued Expression Analysis for Collective Checking. EuroPar, Aug 2019, Göttingen, Germany. ⟨hal-02390025⟩
100 Consultations
157 Téléchargements
