A fully labelled proof system for intuitionistic modal logics
In this paper we present a labelled sequent system for intuitionistic modal logics such that there is not only one, but two relation symbols appearing in sequents: one for the accessibility relation associated with the Kripke semantics for normal modal logics and one for the preorder relation associated with the Kripke semantics for intuitionistic logic. This puts our system in close correspondence with the standard birelational Kripke semantics for intuitionistic modal logics. As a consequence it can encompass a wider range of intuitionistic modal logics than existing labelled systems. We also show an internal cut elimination proof for our system.
Logique en informatique [cs.LO]
