Noiseless coding of correlated information sources, IEEE Transactions on Information Theory, vol.19, issue.4, pp.471-480, 1973. ,
The rate-distorsion function for source coding with side information at the decoder, IEEE Trans. on Inf. Th, vol.22, issue.1, pp.1-10, 1976. ,
Modeling the lossy transmission of correlated sources in multiple access fading channels, Physical Communication, vol.24, pp.34-45, 2017. ,
Models, statistics, and rates of binary correlated sources, Physical Communication, vol.19, pp.70-80, 2016. ,
Distributed source coding for sensor networks, IEEE Signal Processing Magazine, vol.21, issue.5, pp.80-94, 2004. ,
Source coding with side information at several decoders, IEEE Transactions on Information Theory, vol.23, issue.2, pp.179-182, 1977. ,
Rate distortion with side-information at many decoders, IEEE Transactions on Information Theory, vol.57, issue.8, pp.5240-5257, 2011. ,
Universal incremental slepian-wolf coding, Allerton Conference on Communication, control and computing, pp.1757-1761, 2004. ,
On multistage successive refinement for wyner-ziv source coding with degraded side informations, IEEE Transactions on Information Theory, vol.53, issue.8, pp.2946-2960, 2007. ,
Source coding problems with conditionally less noisy side information, IEEE Transactions on Information Theory, vol.60, issue.9, pp.5516-5532, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-02286659
Vector gaussian rate-distortion with variable side information, IEEE Transactions on Information Theory, vol.63, issue.8, pp.5162-5178, 2017. ,
Successive refinement of information, IEEE Transactions on Information Theory, vol.37, issue.2, pp.269-275, 1991. ,
Successive refinement of information: Characterization of the achievable rates, IEEE Transactions on Information Theory, vol.40, issue.1, pp.253-259, 1994. ,
Strong successive refinability and rate-distortion-complexity tradeoff, IEEE Transactions on Information Theory, vol.62, issue.6, pp.3618-3635, 2016. ,
Second-order and moderate deviations asymptotics for successive refinement, IEEE Transactions on Information Theory, vol.63, issue.5, pp.2896-2921, 2017. ,
Free-viewpoint video communication using multi-view video coding, NTT Technical Review, vol.2, issue.8, pp.21-26, 2004. ,
View scalable multiview video coding using 3-d warping with depth map, IEEE Trans. on Circ. and Syst. for Video Technology, vol.17, issue.11, pp.1485-1495, 2007. ,
Interactive streaming of stored multiview video using redundant frame structures, IEEE Transactions on Image Processing, vol.3, issue.3, pp.744-761, 2011. ,
Sensor networks: evolution, opportunities, and challenges, Proceedings of the IEEE, vol.91, issue.8, pp.1247-1256, 2003. ,
Compound conditional source coding, Slepian-Wolf list decoding, and applications to media coding, IEEE International Symposium on Information Theory, 2007. ,
Universal lossless coding with random user access: the cost of interactivity, Proceedings IEEE International Conference on Image Processing, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01208128
Information-spectrum methods in information theory, 2003. ,
An information-spectrum approach to rate-distortion function with side information, IEICE Transactions on Fundamentals of Electronics, vol.85, issue.6, pp.1387-1395, 2002. ,
The distributed Karhunen-Loeve transform, IEEE Transactions on Information Theory, vol.52, issue.12, pp.5177-5196, 2006. ,
Rate distortion when side information may be absent, IEEE Transactions on Information Theory, vol.31, issue.6, pp.727-734, 1985. ,
On the role of encoder side-information in source coding for multiple decoders, Information Theory, 2006 IEEE International Symposium on, pp.331-335, 2006. ,
Lossy source coding with gaussian or erased side-information, 2009 IEEE International Symposium on Information Theory, pp.1035-1039, 2009. ,
Fundamental limits of caching, IEEE Transactions on Information Theory, vol.60, issue.5, pp.2856-2867, 2014. ,
Cache-aided coded multicast for correlated sources, 2016. ,
Distortion-rate bounds for fixed-and variable-rate multiresolution source codes, IEEE Transactions on Information Theory, vol.45, issue.6, pp.1887-1910, 1999. ,
Non-asymptotic bounds and a general formula for the rate-distortion region of the successive refinement problem, IEICE TRANSACTIONS on Fundamentals of Electronics, vol.101, issue.12, pp.2110-2124, 2018. ,
An information-spectrum approach to rate-distortion function with side information, IEEE International Symposium on Information Theory, Proceedings, p.156, 2002. ,
Capacity and coding for the Gilbert-Elliot channels, IEEE Transactions on Information Theory, vol.35, issue.6, pp.1277-1290, 1989. ,
On entropy approximation for gaussian mixture random vectors, Multisensor Fusion and Integration for Intelligent Systems, pp.181-188, 2008. ,
Rate distortion theory: A mathematical basis for data compression, 1971. ,
