, A Mathematical Introduction to Compressive Sensing. Birkhäuser Basel, 2013.
Greed is good: Algorithmic results for sparse approximation, IEEE Trans. on Information Theory, vol.50, pp.2231-2242, 2004. ,
Analysis of Orthogonal Matching Pursuit Using the Restricted Isometry Property, IEEE Trans. on Information Theory, vol.56, issue.9, pp.4395-4401, 2010. ,
The exact support recovery of sparse signals with noise via Orthogonal Matching Pursuit, IEEE Signal Processing Letters, vol.20, issue.12, pp.403-406, 2013. ,
Joint k-Step Analysis of Orthogonal Matching Pursuit and Orthogonal Least Squares, IEEE Trans. on Information Theory, vol.59, issue.5, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00637003
Support reccovery with Orthogonal matching pursuit in the presence of noise, IEEE Trans. on Signal Processing, vol.63, issue.21, pp.5868-5877, 2015. ,
Signal recovery from random measurements via Orthogonal Matching Pursuit, IEEE Trans. on Information Theory, vol.53, issue.12, pp.4655-4666, 2007. ,
Necessary and Sufficient Conditions on Sparsity Pattern Recovery, IEEE Trans. on Information Theory, vol.55, issue.12, pp.5758-5772, 2009. ,
Orthogonal matching pursuit: A Brownian motion analysis, IEEE Trans. on Signal Processing, vol.60, issue.3, pp.1010-1021, 2012. ,
