Full-Stokes spectropolarimetry of solar prominences - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Astronomy and Astrophysics - A&A Année : 2001
We report on first spectropolarimetric observations of solar prominences made at THEMIS. Hereafter we shall emphasis on the preliminary analysis of He i D3 full-Stokes observations. Our measurements clearly show manifestations of both the Hanle and Zeeman effects. More generally, we demonstrate the very favourable performances of the THEMIS multi-line spectropolarimetric mode for further new investigations of the magnetic field in solar prominences.
aadf183.pdf (178.48 Ko) Télécharger le fichier
hal-02393072 , version 1 (24-01-2021)
F. Paletou, A. Lopez Ariste, V. Bommier, M. Semel. Full-Stokes spectropolarimetry of solar prominences. Astronomy and Astrophysics - A&A, 2001, 375 (3), pp.L39-L42. ⟨10.1051/0004-6361:20010927⟩. ⟨hal-02393072⟩
63 Consultations
64 Téléchargements
