Quadrature coherence scale driven fast decoherence of bosonic quantum field states - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Physical Review Letters Année : 2020
We introduce, for each state of a bosonic quantum field, its quadrature coherence scale (QCS), a measure of the range of its quadrature coherences. Under coupling to a thermal bath, the purity and QCS are shown to decrease on a time scale inversely proportional to the QCS squared. The states most fragile to decoherence are therefore those with quadrature coherences far from the diagonal. We further show a large QCS is difficult to measure since it induces small scale variations in the state's Wigner function. These two observations imply a large QCS constitutes a mark of "macroscopic coherence". Finally, we link the QCS to optical classicality: optical classical states have a small QCS and a large QCS implies strong optical nonclassicality.
NCTimescales20190910_HAL.pdf (946.56 Ko) Télécharger le fichier
hal-02394344 , version 1 (04-12-2019)
Anaelle Hertz, Stephan de Bièvre. Quadrature coherence scale driven fast decoherence of bosonic quantum field states. Physical Review Letters, 2020, ⟨10.1103/PhysRevLett.124.090402⟩. ⟨hal-02394344⟩
83 Consultations
56 Téléchargements
