Stabilization of (G)EIM in presence of measurement noise: application to nuclear reactor physics, Spectral and High Order Methods for Partial Differential Equations ICOSAHOM 2016, pp.133-145, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01393704
Error-bounds for finite element method, Numerische Mathematik, vol.16, pp.322-333, 1970. ,
Data assimilation in reduced modeling, SIAM/ASA Journal on Uncertainty Quantification, vol.5, issue.1, pp.1-29, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01352283
Nonlinear model reduction via discrete empirical interpolation, SIAM J. Sci. Comput, vol.32, issue.5, pp.2737-2764, 2010. ,
Karhunen-Loève procedure for gappy data, J. Opt. Soc. Am. A, vol.12, issue.8, pp.1657-1664, 1995. ,
A Reduced Basis Technique for Long-Time Unsteady Turbulent Flows, 2017. ,
Beyond petrov-galerkin projection by using multi-space prior, European Conference on Numerical Mathematics and Advanced Applications (Enumath'17, 2017. ,
Beyond Petrov-Galerkin projection by using multispace prior, Model Reduction of Parametrized Systems IV (MoRePaS'18, 2018. ,
The generalized empirical interpolation method: Stability theory on hilbert spaces with an application to the stokes equation, Computer Methods in Applied Mechanics and Engineering, vol.287, pp.310-334, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01032168
Convergence analysis of the generalized empirical interpolation method, SIAM Journal on Numerical Analysis, vol.54, issue.3, pp.1713-1731, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01032458
, Reduced Basis Methods for Partial Differential Equations, vol.92, 2016.
