Towards a comprehensive impossibility result for string stability
We provide a comprehensive impossibility result towards achieving string stability, i.e. keeping local relative errors in check with local controllers independently of the size of a chain of subsystems. We significantly extend existing results, from the LTI setting to any homogeneous controllers that can be nonlinear, time-varying, and locally communicating. We prove this impossibility for a set of definitions with various norm choices, including the L2-type standard and a BIBO type criterion. All results hold for a general discrete-time controller which should cover most applications.
