Metage2Metabo, microbiota-scale metabolic complementarity for the identification of key species - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue eLife Année : 2020
To capture the functional diversity of microbiota, one must identify metabolic functions and species of interest within hundreds or thousands of microorganisms. We present Metage2Metabo (M2M) a resource that meets the need for de-novo functional screening of genome-scale metabolic networks (GSMNs) at the scale of a metagenome, and the identification of critical species with respect to metabolic cooperation. M2M comprises a flexible pipeline for the characterisation of individual metabolisms and collective metabolic complementarity. In addition, M2M identifies key species, that are meaningful members of the community for functions of interest. We demonstrate that M2M is applicable to collections of genomes as well as metagenome-assembled genomes, permits an efficient GSMN reconstruction with Pathway Tools, and assesses the cooperation potential between species. M2M identifies key organisms by reducing the complexity of a large-scale microbiota into minimal communities with equivalent properties, suitable for further analyses.
elife-61968-v1.pdf (2.88 Mo) Télécharger le fichier
Origine : Publication financée par une institution
hal-02395024 , version 1 (05-12-2019)
hal-02395024 , version 2 (07-01-2021)
Arnaud Belcour, Clémence Frioux, Méziane Aite, Anthony Bretaudeau, Falk Hildebrand, et al.. Metage2Metabo, microbiota-scale metabolic complementarity for the identification of key species. eLife, 2020, 9, ⟨10.7554/eLife.61968⟩. ⟨hal-02395024v2⟩
464 Consultations
593 Téléchargements
