Auto-encoding variational bayes, 2013. ,
Stochastic backpropagation and approximate inference in deep generative models, Proceedings of the 31st International Conference on Machine Learning, vol.32, pp.1278-1286, 2014. ,
Learning structured output representation using deep conditional generative models, Advances in neural information processing systems, pp.3483-3491, 2015. ,
Shakir Mohamed, and Alexander Lerchner. beta-vae: Learning basic visual concepts with a constrained variational framework, vol.ICLR, p.6, 2017. ,
, , 2015.
, Large-scale machine learning on heterogeneous distributed systems, 2016.
Adam: A method for stochastic optimization, 2014. ,
Stacked denoising autoencoders: Learning useful representations in a deep network with a local denoising criterion, Journal of machine learning research, vol.11, pp.3371-3408, 2010. ,
Variational inference for on-line anomaly detection in high-dimensional time series, 2016. ,
Conditional variational autoencoder for prediction and feature recovery applied to intrusion detection in iot, Sensors, vol.17, issue.9, p.1967, 2017. ,
, Generative temporal models with memory, 2017.
Semi-supervised learning with deep generative models, Advances in NeurIPS, pp.3581-3589, 2014. ,
Deep learning for anomaly detection: A survey. CoRR, abs, 1901. ,
Estimating the support of a high-dimensional distribution, Neural computation, vol.13, issue.7, pp.1443-1471, 2001. ,
Isolation-based anomaly detection, ACM Transactions on Knowledge Discovery from Data (TKDD), vol.6, issue.1, p.3, 2012. ,
Scaling learning algorithms towards ai. Large-scale kernel machines, vol.34, pp.1-41, 2007. ,
Opening the black box of deep neural networks via information, 2017. ,
A baseline for detecting misclassified and out-of-distribution examples in neural networks, Proceedings of International Conference on Learning Representations, 2017. ,
Representation learning: A review and new perspectives, IEEE transactions on pattern analysis and machine intelligence, vol.35, pp.1798-1828, 2013. ,
What regularized auto-encoders learn from the data-generating distribution, J. Mach. Learn. Res, vol.15, issue.1, pp.3563-3593, 2014. ,
Variational autoencoder based anomaly detection using reconstruction probability, 2015. ,
Self-adversarial variational autoencoder with gaussian anomaly prior distribution for anomaly detection, 2019. ,
Infovae: Information maximizing variational autoencoders ,
Complementary set variational autoencoder for supervised anomaly detection, IEEE International Conference on Acoustics, Speech and Signal Processing (ICASSP), pp.2366-2370, 2018. ,
Deep anomaly detection with outlier exposure. CoRR, abs/1812.04606, p.19, 2018. ,
Gradient-based learning applied to document recognition, Proceedings of the IEEE, vol.86, issue.11, pp.2278-2324, 1998. ,
Fashion-mnist: a novel image dataset for benchmarking machine learning algorithms, 2017. ,
Disentangling factors of variation in deep representation using adversarial training, Advances in Neural Information Processing Systems, pp.5040-5048, 2016. ,
The CMS experiment at the CERN LHC, JINST, vol.3, p.8004, 2008. ,
URL : https://hal.archives-ouvertes.fr/in2p3-00311605
The Large Hadron Collider, conceptual design, 1995. ,
The CMS trigger system, JINST, vol.12, issue.01, p.1020, 2017. ,
