, No cyclotomic family of embedding degree above 32 satisfying (9) was found. For BN, BLS12, BLS24, KSS16, KSS18, we reproduce in Table 9 the results of Guillevic and Singh [23]: BN with a 1022-bit p, BLS12 with a 1150-bit p, KSS16 with a 766-bit prime p, KSS18 with a 638-bit prime p, BLS24 with a 509-bit prime p. We list in Table 10 seed ranges for k ? {14, 15, 20, 21, 27, 28}. We also refer to [18] for alternative curves with ? = 2. We leave to future work a complete study of pairing-friendly curves at the 192-bit security level, ? 37, and with ? = 2 we obtain k ? 10. Curves like Fotiadis-Konstantinou with exactly ? = 2 satisfy, vol.18
RELIC is an Efficient LIbrary for Cryptography ,
Faster computation of the Tate pairing, Elliptic Curve Cryptography), vol.131, pp.842-857, 2011. ,
Updating key size estimations for pairings, Journal of Cryptology, vol.32, issue.4, pp.1298-1336, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-01534101
A taxonomy of pairings, their security, their complexity, Sept, vol.24, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02129868
The tower number field sieve, ASIACRYPT 2015, Part II, vol.9453, pp.31-55 ,
URL : https://hal.archives-ouvertes.fr/hal-01155635
, , 2015.
Constructing elliptic curves with prescribed embedding degrees, SCN 02, vol.2576, pp.257-267, 2003. ,
, New zk-SNARK elliptic curve construction. Zcash blog, pp.12-381, 2017.
Zexe: Enabling decentralized private computation, vol.962, 2018. ,
Elliptic curves suitable for pairing based cryptography, Des. Codes Cryptography, vol.37, issue.1, pp.133-141, 2005. ,
On instantiating pairingbased protocols with elliptic curves of embedding degree one, IEEE Transactions on Computer, vol.66, issue.6, pp.1061-1070, 2017. ,
Efficient computation of Tate pairing in projective coordinate over general characteristic fields, ICISC 04, vol.3506, pp.168-181, 2005. ,
On cycles of pairing-friendly elliptic curves, SIAM Journal on Applied Algebra and Geometry, vol.3, issue.2, pp.175-192, 2019. ,
Faster pairing computations on curves with high-degree twists, PKC 2010, vol.6056, pp.224-242, 2010. ,
Attractive subfamilies of BLS curves for implementing high-security pairings, DOCRYPT 2011, vol.7107, pp.320-342, 2011. ,
HT90 and "simplest" number fields, Illinois J. Math, vol.55, issue.4, pp.1621-1655, 2011. ,
TNFS resistant families of pairing-friendly elliptic curves, Theoretical Computer Science, vol.800, pp.73-89, 2019. ,
Optimal TNFS-secure pairings on elliptic curves with composite embedding degree, vol.555, 2019. ,
Computing optimal ate pairings on elliptic curves with embedding degree 9, 1187. ,
A taxonomy of pairing-friendly elliptic curves, Journal of Cryptology, vol.23, issue.2, pp.224-280, 2010. ,
, Advances in Elliptic Curve Cryptography, pp.183-214, 2005.
Cocks-Pinch curves of embedding degrees five to eight and optimal ate pairing computation, vol.431, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02305051
On the alpha value of polynomials in the tower number field sieve algorithm, vol.885, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02263098
, Elliptic curve generation, 2 edn, ISO: ISO/IEC 15946-5:2017 Information technology -Security techniques -Cryptographic techniques based on elliptic curves -Part, vol.5, 2017.
The special number field sieve in Fpn -application to pairingfriendly constructions, PAIRING 2013, vol.8365, pp.45-61, 2014. ,
Extended tower number field sieve: A new complexity for the medium prime case, CRYPTO 2016, Part I. LNCS, vol.9814, pp.543-571, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01281966
Extended tower number field sieve with application to finite fields of arbitrary composite extension degree, Part I. LNCS, vol.10174, pp.388-408, 2017. ,
Selecting cryptographic key sizes, Journal of Cryptology, vol.14, issue.4, pp.255-293, 2001. ,
Challenges with assessing the impact of NFS advances on the security of pairing-based cryptography, Mycrypt Conference, vol.10311, pp.83-108, 2016. ,
Five, six, and seven-term Karatsuba-like formulae, IEEE Transactions on Computer, vol.54, pp.362-369, 2005. ,
A family of implementation-friendly BN elliptic curves, Journal of Systems and Software, vol.84, issue.8, pp.1319-1326, 2011. ,
Pairing-friendly curves, 2019. ,
A new family of pairing-friendly elliptic curves, pp.43-57, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01875361
Easy scalar decompositions for efficient scalar multiplication on elliptic curves and genus 2 Jacobians, Contemporary mathematics, vol.637, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-00874925
Fast and simple constant-time hashing to the BLS12-381 elliptic curve, IACR TCHES, vol.2019, issue.4, pp.154-179, 2019. ,
