, When P 1 = P (M 1 ?bm)/am is the distribution of the normalized block maxima and P 2 = G ? is the GEV distribution, we get V 1 (z) = (V (mz) ? V (m))/a(m)
, Since a is regularly varying with index ?, a(m) p e ?m/m 0 ? 0 as m ? ?. Letting m ? ?
Residual life time at great age, Ann. Probability, vol.2, pp.792-804, 1974. ,
, Statistics of extremes. Wiley Series in Probability and Statistics, 2004.
Some asymptotic theory for the bootstrap, Ann. Statist, vol.9, issue.6, pp.1196-1217, 1981. ,
On the maximum likelihood estimator for the generalized extreme-value distribution, Extremes, vol.20, issue.4, pp.839-872, 2017. ,
Maximum likelihood estimation for the Fréchet distribution based on block maxima extracted from a time series, Bernoulli, vol.24, issue.2, pp.1427-1462, 2018. ,
A form of regular variation and its application to the domain of attraction of the double exponential distribution, Z. Wahrsch. Verw. Gebiete, vol.17, pp.241-258, 1971. ,
Extreme value theory, Springer Series in Operations Research and Financial Engineering, 2006. ,
Maximum likelihood estimators based on the block maxima method, Bernoulli, vol.25, issue.3, pp.1690-1723, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-00780279
On smooth statistical tail functionals, Scand. J. Statist, vol.25, issue.1, pp.187-210, 1998. ,
On large deviation for extremes, Statist. Probab. Lett, vol.64, issue.1, pp.51-62, 2003. ,
On the block maxima method in extreme value theory: PWM estimators, Ann. Statist, vol.43, issue.1, pp.276-298, 2015. ,
Limiting forms of the frequency distribution of the largest or smallest member of a sample, Proc. Camb. Philos. Soc, vol.24, pp.180-190, 1928. ,
Sur la distribution limite du terme maximum d'une série aléatoire, Ann. of Math, vol.44, issue.2, pp.423-453, 1943. ,
A simple general approach to inference about the tail of a distribution, Ann. Statist, vol.3, issue.5, pp.1163-1174, 1975. ,
The theory of probability weighted moments, 1986. ,
Parameter and quantile estimation for the generalized Pareto distribution, Technometrics, vol.29, issue.3, pp.339-349, 1987. ,
Estimation of the generalized extreme-value distribution by the method of probabilityweighted moments, Technometrics, vol.27, issue.3, pp.251-261, 1985. ,
Existence and consistency of Wasserstein barycenters, Probab. Theory Related Fields, vol.168, issue.3-4, pp.901-917, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01163262
Lectures on the coupling method, Wiley Series in Probability and Mathematical Statistics: Probability and Mathematical Statistics, 1992. ,
Statistical aspects of Wasserstein distances, Annu. Rev. Stat. Appl, vol.6, pp.405-431, 2019. ,
Statistical inference using extreme order statistics, Ann. Statist, vol.3, pp.119-131, 1975. ,
Fundamentals of Stein's method, Probab. Surv, vol.8, pp.210-293, 2011. ,
, Coupling, stationarity, and regeneration. Probability and its Applications, 2000.
Asymptotic statistics, of Cambridge Series in Statistical and Probabilistic Mathematics, vol.3, 1998. ,
Optimal transport, Grundlehren der Math, vol.338, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00974787
, Berlin. Old and new
Estimation of parameters and large quantiles based on the k largest observations, J. Amer. Statist. Assoc, vol.73, issue.364, pp.812-815, 1978. ,
