A Mechanised Cryptographic Proof of the WireGuard Virtual Private Network Protocol - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Benjamin Lipp
Bruno Blanchet
Karthikeyan Bhargavan
WireGuard is a free and open source Virtual Private Network (VPN) that aims to replace IPsec and OpenVPN. It is based on a new cryptographic protocol derived from the Noise Protocol Framework. This paper presents the first mechanised cryptographic proof of the protocol underlying WireGuard, using the CryptoVerif proof assistant. We analyse the entire WireGuard protocol as it is, including transport data messages, in an ACCE-style model. We contribute proofs for correctness, message secrecy, forward secrecy, mutual authentication, session uniqueness, and resistance against key compromise impersonation, identity mis-binding, and replay attacks. We also discuss the strength of the identity hiding provided by WireGuard. Our work also provides novel theoretical contributions that are reusable beyond WireGuard. First, we extend CryptoVerif to account for the absence of public key validation in popular Diffie-Hellman groups like Curve25519, which is used in many modern protocols including WireGuard. To our knowledge, this is the first mechanised cryptographic proof for any protocol employing such a precise model. Second, we prove several indifferentiability lemmas that are useful to simplify the proofs for sequences of key derivations.
paper.pdf (481.38 Ko) Télécharger le fichier
hal-02396640 , version 1 (06-12-2019)
  • HAL Id : hal-02396640 , version 1
Benjamin Lipp, Bruno Blanchet, Karthikeyan Bhargavan. A Mechanised Cryptographic Proof of the WireGuard Virtual Private Network Protocol. 4th IEEE European Symposium on Security and Privacy, Jun 2019, Stockholm, Sweden. pp.231-246. ⟨hal-02396640⟩
Collections
INRIA INRIA2 ANR
242 Consultations
183 Téléchargements
