New interface
Conference papers
Adapting Rigidity to Symmetric Cryptography: Towards "Unswerving" Designs
Abstract : While designers of cryptographic algorithms are rarely considered as potential adversaries, past examples, such as the standardization of the Dual EC PRNG highlights that the story might be more complicated. To prevent the existence of backdoors, the concept of rigidity was introduced in the specific context of curve generation. The idea is to first state a strict scope statement for the properties that the curve needs to have and then pick e.g. the one with the smallest parameters. The aim is to ensure that the designers did not have the degrees of freedom that allows the addition of a trapdoor. In this paper, we apply this approach to symmetric algorithms. The task is challenging because the corresponding primitives are more complex: they consist of several sub-components of different types, and the properties required by these sub-components to achieve the desired security level are not as clearly defined. Furthermore, security often comes in this case from the interplay between these components rather than from their individual properties. In this paper, we argue that it is nevertheless necessary to demand that symmetric algorithms have a similar but, due to their different nature, more complex property which we call "unswervingness". We motivate this need via a study of the literature on symmetric "kleptography" and via the study of some real-world standards. We then suggest some guidelines that could be used to leverage the unswervingness of a symmetric algorithm to standardize a highly trusted and equally safe variant of it.
Document type :
Conference papers
Complete list of metadata
Cited literature [85 references]  Display  Hide  Download
https://hal.inria.fr/hal-02396695
Contributor : Léo Perrin Connect in order to contact the contributor
Submitted on : Friday, December 6, 2019 - 10:38:52 AM
Last modification on : Tuesday, October 25, 2022 - 4:19:39 PM
Long-term archiving on: : Saturday, March 7, 2020 - 1:12:19 PM
File
eprint.pdf
Identifiers
Collections
Citation
Orr Dunkelman, Léo Perrin. Adapting Rigidity to Symmetric Cryptography: Towards "Unswerving" Designs. SSR 2019 - Proceedings of the 5th ACM Workshop on Security Standardisation Research Workshop, Nov 2019, London, France. pp.69-80, ⟨10.1145/3338500.3360335⟩. ⟨hal-02396695⟩
Share
Metrics
Record views
79
Files downloads
241
