HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Preprints, Working Papers, ...
Karatsuba multiplication with temporary space of size ≤ n
Abstract : We describe in this short note how it is possible to perform a Karatsuba multiplication of two polynomials of degree n − 1 using a buffer holding at most n − 1 coefficients if n is even, and n coefficients if n is odd. This method is valid for any n (in other words, when n ≥ 2). Similar results can be obtained for the Karatsuba squaring.
Document type :
Complete list of metadata
Cited literature [8 references]  Display  Hide  Download
https://hal.archives-ouvertes.fr/hal-02396734
Contributor : Emmanuel Thomé Connect in order to contact the contributor
Submitted on : Friday, December 6, 2019 - 10:52:21 AM
Last modification on : Wednesday, October 14, 2020 - 3:54:02 PM
Long-term archiving on: : Saturday, March 7, 2020 - 2:00:54 PM
File
kara.pdf
Identifiers
  • HAL Id : hal-02396734, version 1
Collections
Citation
Emmanuel Thomé. Karatsuba multiplication with temporary space of size ≤ n. 2002. ⟨hal-02396734⟩
Share
Metrics
Record views
109
Files downloads
198
