On an existence theory for a fluid-beam problem encompassing possible contacts - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal de l'École polytechnique — Mathématiques Année : 2021
In this paper we consider a coupled system of pdes modelling the interaction between a two-dimensional incompressible viscous fluid and a one-dimensional elastic beam located on the upper part of the fluid domain boundary. We design a functional framework to define weak solutions in case of contact between the elastic beam and the bottom of the fluid cavity. We then prove that such solutions exist globally in time regardless a possible contact by approximating the beam equation by a damped beam and letting this additional viscosity vanishes.
CGH.pdf (436.21 Ko) Télécharger le fichier
hal-02396915 , version 1 (06-12-2019)
Jean-Jérôme Casanova, Céline Grandmont, Matthieu Hillairet. On an existence theory for a fluid-beam problem encompassing possible contacts. Journal de l'École polytechnique — Mathématiques, 2021, 8, pp.933-971. ⟨10.5802/jep.162⟩. ⟨hal-02396915⟩
200 Consultations
117 Téléchargements
