Tiling and optimizing time-iterated computations over periodic domains, Proceedings of the 23rd International Conference on Parallel Architecture and Compilation Techniques (PACT '14, pp.39-50, 2014. ,
Static Analysis of OpenStream Programs, Proceedings of the 6th International Workshop on Polyhedral Compilation Techniques (IMPACT '16), 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01251845
Some Efficient Solutions to the Affine Scheduling Problem, I, One-dimensional Time, International Journal of Parallel Programming, vol.21, pp.313-348, 1992. ,
Some Efficient Solutions to the Affine Scheduling Problem, II, Multidimensional Time, International Journal of Parallel Programming, vol.21, pp.389-420, 1992. ,
The Power of Polynomials, Proceedings of the 5th International Workshop on Polyhedral Compilation Techniques (IMPACT '15), 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01094787
On Polynomial Code Generation, Proceedings of the 8th International Workshop on Polyhedral Compilation Techniques (IMPACT '18), 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01958096
The Polyhedron Model, Encyclopedia of Parallel Programming, 2011. ,
Index Set Splitting, International Journal of Parallel Programming, vol.28, issue.6, pp.607-631, 2000. ,
Representing polynomials by positive linear functions on compact convex polyhedra, Pacific J. Math, vol.132, pp.35-62, 1988. ,
Global Optimization with Polynomials and the Problem of Moments, SIAM Journal on Optimization, vol.11, pp.796-817, 2001. ,
Semidefinite Programming vs, LP Relaxations for Polynomial Programming. Mathematics of Operations Research, vol.27, issue.2, pp.347-360, 2002. ,
Sums of Squares, Moment Matrices and Optimization Over Polynomials, pp.157-270, 2009. ,
Tiling for Dynamic Scheduling, Proceedings of the 4th International Workshop on Polyhedral Compilation Techniques (IMPACT '14), 2014. ,
On the complexity of Putinar's Positivstellensatz, Journal of Complexity, vol.23, pp.135-150, 2007. ,
Simplification and Runtime Resolution of Data Dependence Constraints for Loop Transformations, Proceedings of the International Conference on Supercomputing (ICS '17), vol.10, 2017. ,
Positivity and Sums of Squares: A Guide to Recent Results, pp.271-324, 2009. ,
, The K-moment problem for compact semialgebraic sets, Math. Ann, vol.289, pp.203-206, 1991.
An algorithmic approach to Schmüdgen's Positivstellensatz, Journal of Pure and Applied Algebra, vol.166, pp.307-319, 2002. ,
On the complexity of Schmüdgen's Positivstellensatz, Journal of Complexity, vol.20, pp.529-543, 2004. ,
A global optimization algorithm for polynomial programming problems using a Reformulation-Linearization Technique, Journal of Global Optimization, vol.2, pp.101-112, 1992. ,
Converting affine recurrence equations to quasi-uniform recurrence equations, VLSI Algorithms and Architectures, pp.319-328, 1988. ,
