Deep Canonical Correlation Analysis, Proc. Mach. Learn. Res, vol.28, issue.3, pp.1247-1255, 2013. ,
, Variational Inference: A Review for Statisticians, 2016.
Advancing research diagnostic criteria for Alzheimer's disease: the IWG-2 criteria, Lancet. Neurol, vol.13, issue.6, pp.614-643, 2014. ,
On the interpretation of weight vectors of linear models in multivariate neuroimaging, Neuroimage, vol.87, pp.96-110, 2014. ,
Relations Between Two Sets of Variates, Biometrika, vol.28, issue.3/4, p.321, 1936. ,
Nonlinear measures of association with kernel canonical correlation analysis and applications, J. Stat. Plan. Inference, vol.139, issue.7, pp.2162-2174, 2009. ,
NIA-AA Research Framework: Toward a biological definition of Alzheimer's disease. Alzheimer's Dement, vol.14, pp.535-562, 2018. ,
Canonical analysis of several sets of variables, Biometrika, vol.58, issue.3, pp.433-451, 1971. ,
Adam: A Method for Stochastic Optimization, vol.6, 2014. ,
Auto-Encoding Variational Bayes, Proc. 2nd Int. Conf. Learn. Represent. (ICLR2014), 2014. ,
Bayesian Canonical Correlation Analysis, J. Mach. Learn. Res, vol.14, pp.965-1003, 2013. ,
A review of multivariate analyses in imaging genetics. Front. Neuroinform, vol.8, p.29, 2014. ,
Tensor Canonical Correlation Analysis for Multi-View Dimension Reduction, IEEE Trans. Knowl. Data Eng, vol.27, issue.11, pp.3111-3124, 2015. ,
DOI : 10.1109/icde.2016.7498374
URL : http://arxiv.org/pdf/1502.02330
Automated Anatomical Labeling of Activations in SPM Using a Macroscopic Anatomical Parcellation of the MNI MRI Single-Subject Brain, Neuroimage, vol.15, issue.1, pp.273-289, 2002. ,
