An introduction to multi-core system on chip -trends and challenges, Multiprocessor System-on-Chip, pp.1-21, 2010. ,
URL : https://hal.archives-ouvertes.fr/lirmm-00574947
Tradeoff exploration between reliability, power consumption, and execution time for embedded systems, International Journal on Software Tools for Technology Transfer, vol.15, issue.3, pp.229-245, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00923926
, Failure mechanisms and models for semiconductor devices, JEDEC, 2016.
Sixteen heuristics for joint optimization of performance, energy, and temperature in allocating tasks to multi-cores, ACM Trans. on Parallel Computing, vol.3, pp.1-29, 2016. ,
A novel bicriteria scheduling heuristics providing a guaranteed global system failure rate, IEEE Trans. on Dependable and Secure Computing, vol.6, pp.241-254, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00746768
Thermal performance challenges from silicon to systems, Intel Technology Journal, vol.3, 2000. ,
Combined DVFS and mapping exploration for lifetime and soft-error susceptibility improvement in MPSoCs, Design, Automation & Test in Europe, DATE'14, 2014. ,
Thermally optimal stop-go scheduling of task graphs with real-time constraints, Asia and South Pacific Design Automation Conference, ASP-DAC'11, 2011. ,
Energy-efficient fault-tolerant scheduling of reliable parallel applications on heterogeneous distributed embedded systems, IEEE Trans. on Sustainable Computing, 2017. ,
The effects of energy management on reliability in real-time embedded systems, ICCAD'04, pp.35-40, 2004. ,
A critical charge model for estimating the SET and SEU sensitivity: A muller C-element case study, Asian Test Symposium, ATS'17, pp.82-87, 2017. ,
On a bicriterion formulation of the problems of integrated system identification and system optimization, IEEE Trans. Systems, Man, and Cybernetics, vol.1, pp.296-297, 1971. ,
An efficient, adaptive parameter variation scheme for metaheuristics based on the epsilon-constraint method, European J. of Operational Research, vol.169, issue.3, pp.932-942, 2006. ,
Temperature-aware task allocation and scheduling for embedded multiprocessor systems-on-chip (MPSoC) design, The Journal of VLSI Signal Processing, vol.45, pp.177-189, 2006. ,
Computers and Intractability, a Guide to the Theory of NP-Completeness, 1979. ,
, Multicriteria Scheduling -Theory, Models and Algorithms, 2006.
URL : https://hal.archives-ouvertes.fr/hal-01620623
Normal-boundary intersection: A new method for generating the Pareto surface in nonlinear multicriteria optimization problems, SIAM J. Opt, vol.8, pp.631-657, 1998. ,
Abstract interpretation: A unified lattice model for static analysis of programs by construction or approximation of fixpoints, Principles of Programming Languages, POPL'77, 1977. ,
Worst case execution time analysis for a processor with branch prediction, Real-Time Systems, vol.18, issue.2/3, pp.249-274, 2000. ,
Fast and precise WCET prediction by separate cache and path analyses, Real-Time Systems, vol.18, pp.157-179, 2000. ,
A generic and compositional framework for multicore response time analysis, International Conference on Real Time Networks and Systems, RTNS'15, pp.129-138, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01231700
Response time analysis of synchronous data flow programs on a many-core processor, International Conference on Real-Time Networks and Systems, RTNS'16, pp.67-76, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01406145
An extensible framework for multicore response time analysis, Real-Time Syst, vol.54, issue.3, pp.607-661, 2018. ,
Models and algorithms for reliability-oriented task-allocation in redundant distributed-computer systems, IEEE Trans. Reliability, vol.38, pp.16-26, 1989. ,
Basic concepts and taxonomy of dependable and secure computing, IEEE Trans. on Dependable and Secure Computing, vol.1, pp.11-33, 2004. ,
Some effects of redundancy on system reliability, National Symposium on Reliability and Quality Control, pp.385-402, 1960. ,
Impact of bias temperature instability on soft error susceptibility, IEEE Trans. Very Large Scale Integration Systems, vol.23, pp.743-751, 2015. ,
Response-time minimization in soft real-time systems with temperature-affected reliability constraint, 2015 CSI Symposium on Real-Time and Embedded Systems and Technologies, RTEST'15, 2015. ,
TASSER: A temperature-aware statistical soft-error-rate analysis framework for combinational circuits, Fifteenth International Symposium on Quality Electronic Design, 2014. ,
Exploiting structural duplication for lifetime reliability enhancement, ISCA, pp.520-531, 2005. ,
Modeling power consumption and temperature in TLM models, Leibniz T. on Embedded Systems, vol.3, issue.1, pp.1-29, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01339441
, CRC Handbook of Thermal Engineering. Mechanical and Aerospace Engineering Series, 1999.
Temperature-aware scheduling and assignment for hard real-time applications on MPSoCs, IEEE Trans. Very Large Scale Integration Systems, vol.19, issue.10, pp.1884-1897, 2011. ,
An experimental evaluation of the assumption of independence in multi-version programming, IEEE Trans. Software Engin, vol.12, issue.1, pp.96-109, 1986. ,
An algorithm to determine the reliability of a complex system, IEEE Trans. Reliability, vol.18, pp.169-174, 1969. ,
A case for lifetime-aware task mapping in embedded chip multiprocessors, Proceedings of the eighth IEEE/ACM/IFIP international conference on Hardware/software codesign and system synthesis, CODES/ISSS'10, 2010. ,
Efficient task partitioning and scheduling for thermal management in multicore processors, ISQED'15, 2015. ,
Static scheduling algorithms for allocating directed task graphs to multiprocessors, ACM Computing Surveys, vol.31, issue.4, pp.406-471, 1999. ,
Applied Mathematical Programming Using Algebraic Systems, 2007. ,
, Task graphs for free, 2016.
, Embedded microprocessor benchmark consortium
, , pp.2016-2026
Lifetime reliability-aware task allocation and scheduling for MPSoC platforms, Design Automation and Test in Europe Conference, DATE'09, pp.51-56, 2009. ,
TCEC: Temperature and energyconstrained scheduling in real-time multitasking systems, IEEE Trans. Computer-Aided Design of Integrated Circuits and Systems, vol.31, pp.1159-1168, 2012. ,
Improving system-level lifetime reliability of multicore soft real-time systems, PLACE PHOTO HERE Athena Abdi Athena Abdi received the B.Sc. and M.Sc. degrees in computer engineering from Amirkabir University of Technology (Tehran Polytechnic), vol.25, pp.1895-1905, 2010. ,
