Flipping Geometric Triangulations on Hyperbolic Surfaces - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2019
We consider geometric triangulations of surfaces, i.e., triangulations whose edges can be realized by disjoint locally geodesic segments. We prove that the flip graph of geometric triangulations with fixed vertices of a flat torus or a closed hyperbolic surface is connected. We give upper bounds on the number of edge flips that are necessary to transform any geometric triangulation on such a surface into a Delaunay triangulation.
Delaunay-flips-hyperbolic.pdf (606.2 Ko) Télécharger le fichier
Format : Figure, Image
hal-02400219 , version 1 (09-12-2019)
Vincent Despré, Jean-Marc Schlenker, Monique Teillaud. Flipping Geometric Triangulations on Hyperbolic Surfaces. [Research Report] INRIA. 2019. ⟨hal-02400219⟩
186 Consultations
82 Téléchargements
